When I pull up a Library, the “Recommended” tab is populated and I can play media from there. However, if I try to switch to the “Library” view tab, it does not populate with content. This only happens over the cellular connection. If I switch to wifi, it works fine. Not sure if it is due to wifi connection or the fact that the wifi is on local network of the Plex server. Plex reports my server as having remote access.
If I turn my phone’s hotspot on, then connect my laptop to the hotspot, the Windows Plex app access the library tab just fine.
Haven’t had a chance to connect to remote wifi. Included the current version of Plex Server and Player I have, but just updated both of those this morning. This bug has existed in several previous versions of the Android Mobile Beta.
Server Version#: 1.23.0.1435
Player Version#: 8.10.0.21667
