Casting Plex
Hello
I have an issue with Plex on Android : i cannot cast anymore to chrome cast.
The cast icon doesn’t even appear.
Thanks for help
Daniel Diligent
Does the cast icon up here in other apps? Are you sure you’re connected to the Wi-Fi that your cast device(s) are on?
If you restart the Plex app after connecting to the proper Wi-Fi network do the icons appear again?
My experience with all apps that support casting is that will not “adapt” to seeing new devices if you connect to Wi-Fi after they were started.
Hello
Yes the icon appear on others app like vlc. The only way round i found is to unistall and then réinstalle Plex app.
Regards
Daniel Diligent
