Categories and some movies messed up
I’ve spent HOURS getting my movies into categories (yes, I know categories aren’t available in most things… I’m OCD and like the clean-up) and making sure all of my movies are titled correctly and linked correctly to the right movie. This evening I got on and noticed two movies at the top - out of their category and not linked with a movie. I matched them up quickly and added them to the category only to discover that one of the categories was missing - not even an option when I was typing. I went out and checked and the category was still there, but all 9 moves were no longer in it. I checked out the other category from this movie and discovered that it now claimed 6 movies instead of 20. It was still available when I typed the categories but many of the movies that were supposed to be in there no longer had a category listed. The more I looked, the more problems I discovered. Many categories were still showing up with the original collection of photos but now saying there were 0 movies in them. Many more were missing several movies but still had some in them. What happened? I haven’t done anything except watch 1 TV episode on my Roku today. I didn’t change settings, or touch anything or do anything different. I’d appreciate any suggestions. I’m really not looking forward to doing all that work again, only to have it mess up again.
Gramma21
Attached is a picture that shows the category “Princess Diaries” that is now empty but still showing the pictures of the movies that used to be in it. It also shows the “Road Movies” which I had to completely repopulate and “Rooney Garland” which didn’t change at all. The two Bob Hope movies (Princess and the Pirate & The Private Navy of Sargent O’Farrell) WERE both in the “Bob Hope” category, and now are not, although 6 movies remained in that category. I’d appreciate anything anyone can tell me please!!
Thanks!
Tina
the good news for you… Plex does not automatically delete the collections tag (“category”).
the bad news… that doesn’t explain HOW EXACTLY your setup got messed up…
By any chance… Is there anybody beyond yourself who can change the data on your server?
The collections with 0 items means that no movies are left which have this particular collection tag set. This leaves an “empty shell” of the collection (no movies, but the original posters, background and description).
No one but me. And, like I said, the only thing I did was watch a single TV show (not even a movie).
  1. activate debug logging (not ‘verbose’!)
  2. quit Plex Server
  3. wait 1 minute
  4. start Plex Server
  5. wait 5 minutes
  6. fetch log files and attach them here
Or inspect them yourself. Take a look at the Plex Media Server.log file and seek for messages about database corrupt or malformed.
If you find these, you may have to repair your database.
https://support.plex.tv/hc/en-us/articles/201100678-Repair-a-Corrupt-Database
Log files attached
Thanks!
OK, fortunately my suspicion was not correct: your database is not damaged.
When you edit both ‘Princess Diaries’ movies, is there still some content in the Tags - Collections input field?
If so, what exactly?
No, for all of the movies that were no longer in their collections, the tag fields were empty. When I tried to re-add the tag fields, SOME of the tags were still in the drop-down but some weren’t - even though their collection might still be listed (but empty). Does that make sense? I’m trying to explain it correctly.
Thanks!
Tina
As @tom80H mentioned above: even if there is no movie left in a collection, the collection itself will remain until you explicitly delete it.
I understand that. My point is that SOME remained, some did not and some even removed the category from the drop-down suggestions.
Tina
Sometime between last night and this afternoon, it has happened again.
Since this didn’t appear to be a “normal” problem, and since the categories option has started showing on my Roku, I went to the trouble (a week ago) of putting everything back where it belongs. This afternoon, many Bob Hope movies are no longer in the Bob Hope category (some don’t even have the posters showing in the icons), 2 of the Andy Hardy movies are no longer in it’s category etc. What’s happening??? LOL!
Tina
Settings - Server - Agents - Movies - Plex Movie
click on the small ‘cog wheel’ icon at the end of the line ‘Plex Movie’
(wait 2 - 3 seconds, this may take a moment to open)
CLEAR ‘Use collection info from The Movie Database’ - SAVE
Settings - Server - Agents - Movies - The Movie Database
click on the small ‘cog wheel’ icon at the end of the line ‘The Movie Database’
and also:
Go to Settings - Server - Agents - Shows - TheTVDB
In there, grab the line ‘Local Media Assets’ with your mouse and drag it downwards, so it ends up being at the bottom of the stack of active agents.
Repeat the same under
Settings - Server - Agents - Shows - TheMovieDatabase
Settings - Server - Agents - Movies - TheMovieDatabase
Download mp3tag (it is free and doesn’t come with any ‘nasties’)
Install it and then let it loose on your movie folder
click on some of your Bob Hope movies and see if there is anything displayed in the ‘Album’ field
Preferably, this field should be blank.
OK, I changed all the settings and checked all the files. None of them had an album name.
So there were some of these checkboxes ‘filled’?
If so, I’d say monitor the behaviour from now on. It should no longer misbehave.
