Hi
I use the program Filebot to sort my Series and Movies in folders A, B, C and so on and it works fine for the movies, but not with Series and if you have 2 or more Series in the folder A for example it will put all the Series there to the first Series you have there and no other.
So if you first put in the folder A, Altered Carbon (2018) and matched that in Plex all other series that are put into A will be show as Altered Carbon (2018) and no other that I can find.
So my question is if there are another way when Plex is searching for new series from the main folder, without needing to change how it search by changing it to search Folders A, B, C and so on?
Server Version#: 3.104.2
