CCTV - IPCAM/Analog Home Security with R PI3
Folks,
I am building a home security system using Rasberry PI, Can an you please help me fix the following situations
Problem Case 1:
I was trying to process the IP CCTV CAM(HIK VISION) video live stream inside R PI 3(Ubuntu Mate 16.04 & OpenCV 2.4) using Ethernet cable, I am able to get the video stream, but its very very slow(at least a five minute lag). Can you please enlighten me to understand the reason?
Problem Case 2:
I was trying to process analog CCTV Camera(HIK VISION) video live stream video live stream inside R PI 3(Ubuntu Mate 16.04 & OpenCV 2.4), but here, since I was told both DVR and R PI needed to be in the same network(Meaning: Similar IP Address), I had connected the DVR feed to wifi modem and I took the output feed from wifi modem to R PI 3, Please correct me, If this approach is wrong, as its very slow but working
Please also suggest me, If I need to change my approach in both the cases
Guru
(1) Do you even use Plex? There is nothing in your description indicating Plex is used somewhere in the chain :slight_smile:
(2) Are you able to use some hardware acceleration (e.g. via OpenGL) on your Pi in OpenCV 2.4? The CPU in the Pi is much too slow to perform live video processing / conversion → huge delay.
Edit: Moved to RPi category.
Reviewing the OP does not assert or imply any connection to Plex.
The author is requested to create a new thread explaining how this is related to his Plex server.
This thread is now closed.
Judging by the email address, this is just another spammer trying to prime his forum account…
We’ll be seeing some Guru-related spam from him soon. Which will then get his a** banned.
