Centon - InfiniTV 6 ETH or InfiniTV PCI - Does PMS support either?
Server Version#: 1.28.1.6104
Player Version#: Roku
Tuner Make/Model: Current - HDHomerun Prime - Hopefully InfinTV 6
Guide/Lineup name:
Using XMLTV?:
Channel number/Name:
Hello All,
After searching the forum, I find older posts referencing the InfiniTV Tuner appliance. From what I gather, it used to work on older versions of the PMS and no longer works with the latest PMS. I have come across some off-forum discussions in Reddit and the like claiming there is a workaround to using it.
I prefer actual evidence of compliance with PMS before I drop $300 on a new device.
Does anyone currently have any Centon InfiniTV Cable Card devices up and running on PMS?
Is it possible to run any Centon InfinTV devices on PMS?
Thank you in advance,
-Ron
