Support for Ceton (4 and 6 tuner) PCI and Ethernet
Since it was stated no one has specifically requested this, here it is. Many of us that have built our own HTPC or repurposed a PC for this task currently use/run Ceton tuners. I presently have a Ceton Infinity 6 PCI model inside a custom built HTPC with Core i5 CPU, Windows 7 and one Echo device. I would LOVE to keep the use of the tuner and have it work with PLEX. I am not stuck on the use of the Echo personally. The Ceton Infinity tuners come in 4 and 6 tuner types. There are both Ethernet (external) and PCI (internal) models. All work with WMC. If you have the installed tuner limit upgrade (from Ceton), you have access to ALL of the tuners.
Again, adding PLEX DVR/Live support for the Ceton Infinity tuners would be AMAZING.
Thanks.
RW
Ceton tuners are the only other tuners I looked at when I decided on the HDHR years ago.
They would be a great addition to the lineup.
I also have a Ceton 4 tuner card and it works great for me with Windows Media Center but I have to stick with Windows 7. I’d love to transition entirely over to Plex but since it’s working fine now, I’ll stick with it instead of throwing away my hardware investment. At least, hoping to hear if Ceton support is on your roadmap and any eta. Thanks.
I am in the same situation owning a Ceton 4 card that I used with WMC. Since upgrading to Windows 10 I use NextPVR/Kodi which supports Ceton but has its own issues. Plex support for Ceton would be a great feature to have.
Ceton doesn’t even support those cards anymore, they are essentially dead products. I know Plex has limited resources for writing code, so I would rather they focus on products that are still being actively developed.
I agree that I would like to see this, and ASAP. I signed up for PlexPass specifically for this, only to then find out it’s not supported. Probably would’ve been better to put a damn asterisk next to “we now have live TV!” so people didn’t get baited and switched.
Same situation here!! InfiniTV 6 pcie for me. Having Plex as my dvr would finally be an ALL IN ONE solution!
From http://cetoncorp.com/support/ 7/30/2015 (their last post)
“There are currently no alternatives to Windows Media Center for CableCARD protected content on your PC. It’s not a question of Ceton supporting other DVR platforms, all CableCARD tuners are required to use the DRI specification from CableLabs. This freely-available specification allows DVR software packages to control CableCARD tuners and access copy-freely content. To access Copy Once content the DVR software must implement a CableLabs-approved form of copy protection, typically WM-DRM from Microsoft. This is why MythTV, Sage TV, XMBC, etc. do not support protected content.”
IIRC, infinitv doesn’t work without the cablecard and I don’t think the Plex team wants to seek certification due to the expense. Just a guess.
There has ALWAYS been a list of supported devices.
@aschmidtm said:
From Ceton - Powered by Kayako Help Desk Software 7/30/2015 (their last post)
I believe since Android 6, WM-DRM and PlayReady 1-2.0 support and licensing is built right into the OS so technically they could write the required support for AndroidTV based devices such as the Nvidia Shield. The issue from a windows perspective is rewriting the way that Plex performs its recording and playback to support the PlayReady libraries. Now for 4k support, etc we would have to have Kabylake based CPUs and TVs that support HDCP 2.2 to play any new PlayReady 3.0 based content. No matter how many hundreds of thousands that Microsoft would charge for licensing I am pretty sure the community at large would raise most of the capital through a Kickstarter campaign. Its only a matter of time before all cable companies begin to encrypt their channels so the sooner the Plex Developers embrace DRM the less likely they will be backed into a corner with a DVR feature that can’t record anything.
Actually, InfiniTV DO work with OUT the cable card inserted. It is in the manual how to do it. (paraphrasing: while setting up WMC for TV signal, you remove any existing card inserted and proceed with channel discovery.) You would have to have an antenna connected to receive OTA channels. I know this works. When I moved in 2014 and was waiting for new installation of service, I inserted the InfiniTV into another computer and set it up just like that. And I got regular OTA channels. The card would also tune any non-scrambled cable QAM channels. Unfortunately, Verizon FiOS now scrambles nearly ALL so that isn’t as useful. But I can say for a FACT, InfiniTV cards can tune channels WITHOUT a cablecard inserted in them.
For any DVR platform to actually work and be useful to a customer and be accepted by broadcasters/content owners, THERE must be some type of DRM to ensure ‘lazy’ copying aka easy as copy/paste isn’t an issue. Even with current WMC copy once programs, I can run them thru MCEBuddy and strip copy protection and reduce file size (ALL benefits TBH). But the casual user probably wouldn’t get into that. I don’t even do it honestly. I simply want a DVR solution I control. ie how much storage, tuner count, etc. At the Ceton released the InfiniTV 6 it was the ONLY tuner on the market that supported 6 streams. Even the much fawned about (these forums) SiliconDust with it’s ‘actively’ developed products does NOT make a single unit with more than 3 tuners. And the commercial 6 tuner versions SiliconDust makes are like 2 grand and are NOT actively marketed anymore.
SiliconDust can enjoy all the fellating on these forums. You still can’t say it makes the most tuners. As for my Ceton InfiniTV 6 PCI, it has been running 24/7 since 2012 flawlessly.
I believe that there is a large group of WMC users with ceton tuners. Like myself, I am waiting for the opportunity to jump over to a PLEX only environment and leave WMC behind if PLEX were to support the Ceton tuners. Please consider supporting the ceton tuners. (I’ll be glad to support testing the eth-6). Except for premium channels (HBO etc), I’m getting all channel copy freely, like the FCC intended (and for OTA they are requiring) - so I’m not sure what the big “DRM” issue is
I have an InfiniTV 6 PCI and LOVE IT! Been working great! Please add support for this device! :slight_smile:
I’m glad so many of us ceton owners are coming to the surface! The issue with “DRM” support does not effect all of us but for those of us forced to deal with time warner ( spectrum ), were not so lucky. The company decided to put copy-once flags as well as copy-never on almost all channels. Even getting to the point of putting them on some local channels. In the end. Time Warner customers that use cable cards are rendered useless once Windows Media Center looses support. Wmc is the only option with DRM support, as far as I know. If anyone has another option
TELL ME PLEASE!!!. Plex! Be my savior!!
I haven’t tried in years (2012), but I built a new HTPC. And after much debate bought another Ceton. I will try to record a copy once (premium level channel) and run it through MCEBuddy to see if it strips the DRM. I believe it does (or did) but I don’t actively use MCEBuddy, so I can’t say it still works. If it does
a hack to make PLEX work RIGHT now with Ceton SORT OF would be to let WMC record, once complete MCEBuddy would strip (if it still strips DRM) and converts to a smaller file. You could then have a script or batch file run say every few hours and it would move that NEW smaller DRMfree file to the NAS or computer that is running PLEX.
It isn’t pretty or simple, but if MCEBuddy still strips DRM, it would work for adding and sharing content you have recorded. I know for a FACT anything recorded without copy restriction, once run through MCEBuddy and moved to my TV Shows folder, shows up and is shareable. Just happens to be way too manual for most ppl.
Another Ceton user here InfiniTV 4 internal tuner. Would love to use this with Plex DVR and live tv. Looking for a solution to WMC before it is sunseted.
I also have InfiniTV 6, I used used to use it with WMC now moved over to Kodi. I’m using nextpvr as the backend. This setup is ok. I would love to have it running in plex. Please support this device!!!
Just bought another InfiniTV 6, ETH this time. I am VERY happy with my Ceton products. I get some ppl have/are/want to switch to SiliconDust tuners. However, SiliconDust hardware hasn’t been developed further either, and they simply adding PVR type software. That is really the ONLY new development on SiliconDust end. I see no reason Ceton tuners can’t be added. Plex has established its desire to be certified for DRM on cable card side.
PLEX we are waiting for YOU!
I have the PCI InfiniTV 4 & 6 in my WMC box. I will immediately jump ship to Plex once they support it, and I’ll happily pay through my nose for it too.
