CentOS 7 Installation Failing
Server Version#: 1.14.1
Player Version#: 3.87.2
Installing server on CentOS 7 via GNOME desktop, I run the RPM file and it opens Application Installer with the error “Sorry, something went wrong”, I tried manually installing the file by running “sudo yum install /path/to/downloaded/rpm/file” and it seemed to install it, but when running “systemctl start plexmediaserver” it starts, and 127.0.0.1:32400 says “this xml file does not appear to have any style information associated with it” then shows me some HTML/CSS.
Suggestions? I am fairly new to Linux, but I did read through the entire “about server Linux” and “Linux beginners guide” for this kind of issue before posting.
Try 127.0.0.1:32400/web
Also, systemctl status plexmediaserver
