Cert does not match - DNS error
Point of order.
You might want to take care of all the .grab (DVR) directories. they should be owned by PlexMediaServer:PlexMediaServer.
Apparently DSM didn’t pick them up when you changed permissions and did the “Apply to this folder, subfolders, and files”. (or did you forget? :wink: )
Aug 03, 2022 20:58:34.545 [0x7f63c3c64b38] ERROR - Couldn't check for the existence of file "/volume1/Plex/Movies/.grab": boost::filesystem::status: Operation in progress: "/volume1/Plex/Movies/.grab"
Aug 03, 2022 20:58:34.546 [0x7f63c3c64b38] ERROR - Couldn't check for the existence of file "/volume1/Plex/TV Shows/.grab": boost::filesystem::status: Operation in progress: "/volume1/Plex/TV Shows/.grab"
Which URL are you accessing the server with?
Are you using a plex.direct URL?
Something isn’t adding up.
127.0.0.1 is the server talking to itself.
Aug 03, 2022 20:58:34.702 [0x7f63c6d56b38] DEBUG - Completed: [192.168.4.4:49184] 200 GET /media/providers (80 live) GZIP 21895ms 4876 bytes (pipelined: 1)
Aug 03, 2022 20:58:34.702 [0x7f63c6d79b38] DEBUG - Completed: [192.168.4.4:65517] 200 GET /media/providers (80 live) GZIP 52170ms 4876 bytes (pipelined: 1)
Aug 03, 2022 20:58:34.702 [0x7f63c6d56b38] DEBUG - CERT: incomplete TLS handshake from 127.0.0.1:59056: stream truncated
Aug 03, 2022 20:58:34.702 [0x7f63c6d56b38] DEBUG - CERT: incomplete TLS handshake from 127.0.0.1:59060: stream truncated
Aug 03, 2022 20:58:34.703 [0x7f63c6d56b38] DEBUG - CERT: incomplete TLS handshake from 127.0.0.1:59058: stream truncated
Aug 03, 2022 20:58:34.703 [0x7f63c6d79b38] DEBUG - Completed: [192.168.4.4:65518] 200 GET /media/providers (80 live) TLS GZIP 52167ms 5006 bytes (pipelined: 1)
Aug 03, 2022 20:58:34.704 [0x7f63c6d56b38] DEBUG - Completed: [192.168.4.4:49185] 200 GET /media/providers (80 live) TLS GZIP 21887ms 5006 bytes (pipelined: 1)
Aug 03, 2022 20:58:34.704 [0x7f63c6d79b38] DEBUG - Completed: [192.168.4.4:65448] 200 GET /media/providers (80 live) GZIP 92710ms 4876 bytes (pipelined: 1)
Aug 03, 2022 20:58:34.704 [0x7f63c6d56b38] DEBUG - CERT: incomplete TLS handshake from 127.0.0.1:59064: stream truncated
Aug 03, 2022 20:58:34.705 [0x7f63c6d56b38] DEBUG - CERT: incomplete TLS handshake from 127.0.0.1:59066: stream truncated
Aug 03, 2022 20:58:34.706 [0x7f63c6d79b38] DEBUG - CERT: incomplete TLS handshake from 127.0.0.1:59062: stream truncated
We might need to manually remove the stored certificate and have it download fresh
(the P12 file in the “Caches” directory)
