Server Version#: 1.42.2.10156
Player Version#: 2025.30.0 Android
Having issues with my plex server. For some time now I have not been able to use my Android client to access my library. I have setup remote access and it says that it is not reachable on the port. However, if I connect to my public IP address with the port I can access my Plex library.
Thinking that my problem is my equipment I have done the following:
- Upgraded Debian to the latest versions.
- Added server: private-domain: “plex.direct” in appropriate formatting to my pfsense box. (Which it was working before without this)
- Left the server powered off for a couple of hours and then back on.
- Cleared all storage from my Android Plex app and re-signed in.
Any other thoughts?
I am also seeing in the logs:
Nov 29, 2025 23:42:16.101 [139626555050640] WARN - [CERT/OCSP] getCertInfo failed; skipping stapling
Nov 29, 2025 23:42:16.102 [139626555050640] INFO - Running migrations. (EPG 0)
Nov 29, 2025 23:42:16.233 [139626555050640] INFO - Running migrations. (EPG 0)
Nov 29, 2025 23:42:17.958 [139626412321592] WARN - Crash: Crash reporting disabled
Nov 29, 2025 23:42:18.437 [139626463324984] INFO - SQLITE3:0x80000001, 283, recovered 149 frames from WAL file /var/lib/plexmediaserver/Library/Application Support/Ple>
Nov 29, 2025 23:42:18.492 [139626463324984] INFO - Running migrations. (EPG 1)
Nov 29, 2025 23:42:18.541 [139626427271992] WARN - [DatabaseFixups/35DatabaseFixupsConsolidatePeopleTags] Held transaction for too long (/home/runner/_work/plex-media->
Nov 29, 2025 23:42:18.607 [139626418649912] INFO - LibraryUpdateManager path watching is disabled
Nov 29, 2025 23:42:18.870 [139626457713464] WARN - [EventSourceClient/pubsub/172.104.216.125:443] MyPlex: attempted a reachability check but we’re not yet mapped.
Nov 29, 2025 23:42:19.219 [139626405993272] ERROR - CERT: Error acquiring new certificate: Failed to upload CSR: 429,
