Certificate can't load
Hello, I’m trying to setup costume certificate on my Plex server which is running on windows server 2019 (latest update). The certificate can’t even load, there is only the predefined plex cert. I have placed my costume certificate in c:\wacs. NO password used for the cert. Server was restarted after saving the changes in settings. I also tried reseting browser history from “all the time”. Domain is payd and has PTR and A records checked.
For generating certificate I’ve used win-acme v2.2.8.1635.
I tried rsa and elliptic curve privete key.
NO password used
genereted to pfx format
X509 Certificate:
Version: 3
Hash Algorithm: 4 (SHA256)
Signature Algorithm: 3 (ECDSA)
Public Key Length: 384 bits
I have included the settings of the win-acme and the cert details for inspection in atachment zip file.
cert_info.zip (15.0 KB)
I would like to know if there are any issues with specific length or algorithm used for generating the cert for Plex.
Server Version#: 4.125.1
Self-signed certificates are useless.
You need a commonly trusted certificate, like those from e.g. Let’sEncrypt (which is also what Plex uses out of the box)
https://support.plex.tv/articles/200430283-network/
So I finally found out what was the problem. The signature hash is sha 256 which is not supported. Chaged it to sha 1 and it works.
