It is possible that you have hidden files on and normally Windows hides all files in the root of C by default. They viewing Hidden Files.
Also Note if you plan to use the New Network Profile Add process (rather than iPhone Config utility) then you actually need to rename the .der to .cer)
The PlexConnect wiki guide does not contain the .der typo.
