Server Version#: 1.32.8.7639
My server is connected to internet via Starlink satellite, which is CGNAT, i have good local network connectivity at full speed, and remote access via the relay only.
I recently setup a VPN with dedicated IP and when this is enabled, i can remotely access the server directly, however, my internal network loses local connectivity and connects via remote, confirmed with plex dash. When i disconnect vpn, it connects via local network at full speed again. My server is setup with a teamed NIC (1-3) at 3GB, and i have a fourth NIC setup at 1GB. Is there a way to dedicate remote access via vpn through lets say NIC 4, and local access on the teamed NIC. Note, in network setup, i can see all of these NIC and the VPN as options under the preferred local network option, however, when vpn is connected, it does not matter which NIC i select, the local network apps connect remotely, not locally. Many thanks
