Plexamp 3.7.1 for iOS
I change cellular music quality from 128 Kbps to 192 Kbps but the player still show Opus at 128 Kbps playback.
Perhaps it’s already cached at the Opus quality?
I have try with all the cellular music quality and before every change I delete the caches and I can play in 64 Kbps, 96 Kbps, and 128 Kbps but it doesn’t play higher than 128 Kbps.
Delete caches, set quality high, play the item, and post logs.
Thanks for the help, question, the logs created by Plexamp in Advanced Debugging settings or by Plex Media Server?
Plexamp.
Here is the logs, most of the songs I play are Flac and I use 320 Kbps and 1 Mbps settings and most of the songs play at 128 Kbps.
Plexamp-Logs-2021-10-04-1.zip (308.1 KB)
Just looking at some recent plays, it looks like your quality setting for cellular is 192 kbps; network type below is Cellular = 1, WiFi = 2.
Oct 04, 2021 18:49:35.484 [0x6d063000] INFO - BASS: Network switched to 1.
Oct 04, 2021 19:03:00.961 [0x6cfd7000] INFO - Media: Passing on an item with bitrate 941 and codec 'flac'.
Oct 04, 2021 19:03:00.961 [0x6cfd7000] INFO - Media: Couldn't find item with supported codec and bitrate under 192, transcoding.
Oct 04, 2021 19:03:12.403 [0x6cfd7000] INFO - Media: Passing on an item with bitrate 910 and codec 'flac'.
Oct 04, 2021 19:03:12.403 [0x6cfd7000] INFO - Media: Couldn't find item with supported codec and bitrate under 192, transcoding.
Oct 04, 2021 19:03:28.579 [0x6d5db000] INFO - Media: Passing on an item with bitrate 989 and codec 'flac'.
Oct 04, 2021 19:03:28.579 [0x6d5db000] INFO - Media: Couldn't find item with supported codec and bitrate under 192, transcoding.
Oct 04, 2021 19:03:36.168 [0x6d063000] INFO - Media: Passing on an item with bitrate 862 and codec 'flac'.
Oct 04, 2021 19:03:36.168 [0x6d063000] INFO - Media: Couldn't find item with supported codec and bitrate under 192, transcoding.
Oct 04, 2021 19:03:40.866 [0x6d207000] INFO - Media: Passing on an item with bitrate 913 and codec 'flac'.
Oct 04, 2021 19:07:36.550 [0x6d923000] INFO - BASS: Network switched to 2.
That’s the quality I want 192 kbps but it never play at that quality or maybe it’s playing in 192 kbps but Plexamp show it as 128 Kbps.
Sorry I don’t know what you mean by “network type below is Cellular = 1, WiFi = 2”.
you’re misunderstanding the quality setting. the 192 kbps is the cutoff above which it converts.
if you’re trying to change the quality at which the conversion is performed, that is a setting in advanced > conversion bitrate. we don’t recommend changing it because Opus is transparent at 129 kbps and raising the quality level is just a waste of bits.
Ok thanks for the clarification and good night.
