PlexAmp - Downloads don't seem to honor quality setting setting
PlexAmp is set to Automatic for downloads quality
Automatic says it will honor the settings based on network location. I have it set to 128kbps for cellular. When playing, it’s fine, the 320kbps MP3 is converted to Opus @ 128, so it knows I’m on cellular. When downloading, it stays at 320. I think this must be a bug?
If I set downloads manually to 96kbps, then it reports the download as 128kbps opus. Something is off…
This is actually because of a server bug, bitrates lower than 128 don’t work so we had to fudge things here :slight_smile:
Hmm, possibly. Can anyone else reproduce this one?
Looks like adjusting the wifi max bitrate will make downloads honor the correct conversation bitrate setting just not the cellular setting. I tested on a Pixel and iPhone, seems the same.
Can you DM me a set of logs after downloading on cellular? The code looks fine over here.
Done.
