Hello Plex people,
First, I’d like to thank you for your really awesome program, everybody at Plex should be proud of their work. It’s really great and greatly appreciated.
I have a feature request, it’s not so much as requesting adding a feature as much as adjusting a current feature. In a music library, the server software will display tracks in up to 3-digits which I’m sure everyone thought would be plenty and never exceeded. Well… I’m exceeding it but not in it’s normal way.
I’ve collected the CBS Radio Mystery Theater… an old time radio show of mysteries, crime, thrillers, supernatural, and macabre stories. The problem is… there’s over 1,000 of them so only the first 999 will properly display. Starting with episode 1000 it only displays as episode 100 due to the 3-digit limitation.
My current workaround is I just put the 4-digit episode number in the title but if you could change the 3-digit limitation to 4-digits that would be great.
Regardless, thanks for the awesome product!
