Changed Library Drive - Home Screen Error
I moved my libraries to another drive. All went well, except for when I try to play from the home screen. For example I am attempting to resume playing a movie that I was watching, if I try from the Home Screen “Continue Watching” section it gives me a playback error and states “Please check that this file exists and the necessary drive is mounted.” What is funny is that it shows exactly where I was in the movie. If I go to the library and play it from there, no issue. How do I fix this?
Which player if it matters. Have you tried using “Remove from Continue Watching” then playing a bit directly from library to get it on CW again, and trying again?
Seems to only happen on my Roku. I didn’t know that removing from continue playing was an option there, I will try it.
So if I remove it and play from Library and then go back to CW, it works. The funny thing is that this is happening with movies that weren’t started until after the drive change.
