Changed to SSD and now Plex wont find my library
Server Version#: 1.32.5.7349
Linux Mint
**Never used forums before so please be gentle :slight_smile: **
I just upgraded my computer from a SATA drive to an SSD. All of my media files are on a second SATA drive directly connected in the tower.
After installing the latest Plex Media Server and mounting my 2nd drive by editing my /etc/fstab file and TRYING to adjust the folder permissions, when i open Plex Media Server it sees my media folder but not any of the content inside it.
My files are organized into their own folders.
If I plug back in my old SATA drive - it works fine. Please note that system is running 1.31.2.6810. I tried to install that on my new system as well but same issue.
Now if I move my media to the built in Plex folder (/var/lib/plexmediaserver/Library) it works but I did not have to do this on my old drive.
Here are how my permissions are set:
Old:
drwxr-xr-x 5 doug doug 4096 Sep 10 12:18 Videos
doug@pcname:~$ ls -l Videos/
total 8
drwxr-xr-x 3 doug doug 4096 May 7 16:28 ā€˜Movie Name’
drwxr-xr-x 2 doug doug 4096 Sep 10 12:18 Media
doug@doug-Aspire-TC-281:~$ ls -l /var/lib/plexmediaserver/Library/
total 4
drwxr-xr-x 3 plex plex 4096 May 4 2019 ā€˜Application Support’
doug@pcname:~$
New:
doug@pcname:~$ ls -l /home/doug
doug@pcname:~$ ls -l /var/lib/plexmediaserver/Library/
total 8
drwxr-xr-x 3 plex plex 4096 Sep 7 06:17 ā€˜Application Support’
I changed my media folders permissions to plex:plex instead of doug:doug and that did not help either and I could not create new folders so i had to revert. Again - did not have to do this my old system.
Any advice is greatly appreciated. Thank you
Another thing i should note is that on my old system I have a icon for Plex Media server in my Start - Sound & Video menu.
I do not have this on my new system so I thought it might be a bad install. But i have reinstalled a few times and even reimaged the whole computer again but this issue remains as well.
Please post your server logs and an example path and file name of an affected video
  1. Never put media in /var/lib/plexmediaserver. That’s the Plex internal directory. If you make any kind of mistake, you’ll blow up Plex. (I’ve seen it happen more times than I can count)
  2. You probably need to address using this again.
    – /media is owned by Nautilus and the automounter
    – unless expressly mounted by /etc/fstab, the automounter only grants permission to your username, Plex is excluded
  3. Linux Tips - #2 by ChuckPa
@ChuckPa Thanks but I have expressly mounted the drive in my /etc/fstab. Is there any kind of edit I need to make to this? This is the same entry on BOTH my old and new systems and it works on the old system ;(
#Mount for Plex
UUID=(hiding this) /home/doug/Videos ext4 defaults 0 0
/swapfile none swap sw 0 0
Don’t put media in /home/username. You’re asking for trouble and Mint (not-supported) is famous for making a mess of putting media in $HOME.
  • Make /home/videos, permission 755, now mount there
  • Set your username as owner of the directory.
Rule of Linux:
  1. Set the mount point directory permissions FIRST
  2. Mount the filesystem
  3. Set the mounted filesystem permissions if needed LAST
Chuck - your a genius
I did as you said and now Plex can see my files.
I am curious as this is the same permissions I had set on my /home/username/Videos folder and it did not work.
Can you explain more?
Thanks again :smile:
You’re using Mint.
  • Mint isn’t supported because it’s an unstable derivative of Ubuntu.
    I’ve had many cases where Mint works great as a desktop Linux (which is true) but the moment it gets pressed to run a server then it falters.
  • I once spent about 2 full days tracking a phantom problem which I could not reproduce. When I confirmed the user was using Ubuntu/Debian/Redhat/Fedora is when I got ā€œMintā€ as the reply. When the user reinstalled using Ubuntu, ALL the problems were immediately gone. No anomalies / issues at all.
  • Mint does things their way which goes against the majority of the community.
  • How Mint sets permissions on directories and how it manages /home/USERNAME is different than the other distros.
Because of all this, and their changing the rules from version to version, it’s not stable enough to vet and support.
