Changing Plex file location, prevent thumbnail regeneration
Hi All,
I have quite a large database of files. Currently, I am using mergerfs filesystem to show the files all within one directory. However, it is quite slow and limiting.
As such I want to point plex directly to the individual drive locations.
I understand I can follow Move Media Content to a New Location | Plex Support however doing this will trigger plex to regenerate the thumbnails for all media which will take weeks or months. I want to avoid this.
I am thinking of writing a script that will do the following
  1. Update plex db directories table to reflect the updated locations
  2. Update plex db media_parts to reflect the new location.
However, I don’t understand
  1. how plex detects if a file has changed which triggers regeneration of thumbnails.
  2. how plex stores/grab the thumbnails for a file and if there is anything i need to change
  3. if this will even work.
NOTE, I understand the risks of editing the DB directly, I just can’t see any alt method.
Appreciate the guidance on the above.
Thanks!
Wrote a quick script to update media_parts table directly, worked well. plex didn’t regenerate thumbnails.
