Nevermind I see it did not find channel Identifiers. I must need to re-do the application. They may have changed how the information is stored.
Trying to move from Win7 MCE and giving Plex Pass a tryā¦
Running into this issue with Plex showing both sets of tuners for my WinTV-QUAD tuner buy only watching /recording 1 show from each tuner at a time which prevents me from utilizing all 4 Tuners simultaneously, ie to record 2-3 shows and watch another one live.
Is this program verified to fix the issue on Win7?
if so, how the heck has PLEX not fixed this problem in new releases after a year and a half?!?
I just havent had time to see what they have changed to fix the issues in the current version.
This will fix your problem. I have a different program going for homerun tuners in testing.
Is there a current link to the latest version of your channel fixer? Iāve lost a channel through scanning and canāt get it backā¦Iām thinking your software might fix it for me. Thanks!
the downloads at the top should still work for wintv quad tuners. Theres a chance you may have to add the channel manually if its not a duplicate. I had to do with a few myself.
Hi LordProgrammer,
How is it going on Mac support and HD Homerun support? Iām having problems with missing channels and wrong channel names. My HD Homerun shows 62 channels, Plex only shows 45. Iām willing to help beta test (though how regularly is up to my 2-year old and whether he lets me).
Thanks in advance.
Is your plex running on mac
The link goes to " Oops! That page doesnāt exist or is private." Is there another link I should be using?
