After I watch a show, I’ll go back to the guide , only to find that the guide is not showing the current time… The only way to refresh the guide is to back out to the main plex screen and then go back in to live tv…
Is there any way to fix this…
I’m running the latest version of plex…
server or app? if so which one.
Thanks for the quick response…
It’s running on a Ubuntu linux server…
version 14.04.5 LTS
bob
Has anyone else had this problem? Any ideas on how to fix this…
It’s crazy to back out to the main screen then go back into channels, then find the program, then hope you don’t get the dreaded " an error has occurred, please try again later "
Any Ideas ??
Bob
If you’re using the web interface, pressing F5 and going back into the guide usually fixes the problem. A long-standing problem now. I’m so fed up with Plex right now. They’re AWOL. I’m looking into Emby right now even though I paid for a lifetime Plex Pass (foolish me!). I also can’t set up my DVR again because Plex’s TV guide provider isn’t responding.
I’m using plex with an Amazon fire TV…
Sorry forgot to mention that…
Bob
I’m sorry to hear that. I thought that problem was web-only…
I’m using the web app on a windows 10 machine and when I go to the guide it updates perfectly
The only problem is on the Amazon Fire TV…
Bob
I can not believe that no one else has this problem, and that this is a problem in the first place, a simple call to get system time and update the program schedule…
Is there any support for plex ??
Bob
