Scrolling right in tv guide
I have noticed today since the latest update that when you click the little arrow in top right hand corner of the guide to change the time to later in the day it refreshes the whole page view. This is a pain in the ■■■■ if you are looking for what is going on later in the day on a channel that is off the bottom of the view as every time you move right by half an hour you need to then scroll down to your channel again. Only noticed its started doing that since latest update
Server Version#: 1.23.1.4528
Player Version#: 4.57.2
Tuner Make/Model: HD Homerun Connect, HDHR Quadro, TellyTV
Guide/Lineup name: BT TV
Using XMLTV?: no
The page does not refresh for me. What browser and OS are you looking from? I’m on Chrome in Windows 10.
Oh, I can reproduce with the Live TV from Plex guide, but not my local one.
Actually, I think it’s the latest version of the hosted Plex Web. On my local bundled version, it doesn’t refresh. Can you check if you see the same?
Server Version#: 1.22.1.4228
Latest version of the Plex web refreshes the tv guide every time when paging left and/or right which is slightly annoying. This happens on Chrome as well as Microsoft Edge.
Using win 10, edge chromium
I just noticed it’s happening to me as well after installing the latest update. It is a pain to have to scroll back to where you were.
I see this problem still hasn’t been fixed why? Just installed recent update and it has the same problem. I guess I will have to go back to an older version that works properly. Great!! support Plex.
This has been fixed for me. What version of Plex Web are you using? If you are using the local bundled version from an old PMS, it may not have the fix.
