I am in the Rochester, NY area, Zip Code 14622. One of the local low power broadcasters has added a channel to their digital line up and the list of channels for mapping does not include it.
The added channel is 6.6 WGCECD6 this channel shows paid programs most of the day. The listings do include 6.1 - 6.5 but not the new channel 6.6, can you add it to the list so I can map it to my tuners channels. Is there a way I can edit the list of available channels or tell that one channel that it just does not have EPG data but it is OK to add it to the guide. It appears that without being mapped the channel is ignored. I give it a check mark and click save, but if I go back and check it is unchecked and not included in the guide. Thank You.
