Missing Channels In Guide In Rochester, NY 14622
Server Version#: 1.32.7.7621-871adbd44
Guide/Lineup name: Local Broadcast Listings (55 channels)
There are missing and incorrect channel listings in my guide for Rochester, NY 14622, USA local over the air channels. If there is no guide source for a channel, that channel can not be include in the list and can not be watched. The tuner finds these channel but there is no guide source to map to the channel. Missing are channels 6.6, 6.7, 6.8, 20.1 and 42.4, the source for 42.3 is not correct. These stations have added and changed channels but the list source does not always reflect the changes. There should also be an option to add a channel to the list even if there is no guide data for that channel so at least it can be watched even if the program listings are missing.
I’d recommend adding your issue to this thread along with specific details, i.e. the current channels with errors along with what the correct data should be (including references to definitive guide data references, if possible).
