Channel Scan=650 channels
so i hooked up my cable card and my HDHR prime and i connected my plex Dvr and i did a channel scan and great i get over 600 channels!
but we all know this isnt so great its more like 100 channels and about 3 x the duplicates per network
you got your SD channel then get your HD channels then you get all youre music channels and a million other crap channels.
my question is how can i select show only HD channels when i setup my Dvr why is there no option for me to select only HD channels then it well ask me to select my favorites then it well ask me if i want music channels
if only i could choose the channels i want and only have them be in HD.
idk about you but going threw a list of over 600 duplicate channels can be painful and confusing when you see the same network like 3 other times down the list.
Simple double clicks in the HDHomerun setup.
I have the same and it took all of about a half hour to do on my 2 primes.
HD channels show up as avc on the right side of the list so quite easy.
These settings then carry over to all additional software that utilizes the tuner instead of just one.
