Server Version#: 1.21.3.4021
Player Version#: All versions
Has anyone else noticed that Plex is not reading the chapter timestamps correctly any longer ?
All chapter timestamps are now exactly 10:49 (10min 49sec) off from the actual timestamp - meaning, that if the movie chapter starts at 11min 38seconds into the movie, choosing the chapter in Plex will start playback of the chapter at 0:49 seconds.
If I’m playing the same file in VLC or basically any other player, the chapter is correct however playing in Plex (regardless of the player client), the chapter will be off.
In the past, rescanning files in the library would fix any issues with incorrect chapter times however that doesn’t seem to be working any longer.
I’ve even tried removing the movie from the library and then re-adding it hoping that it will cause the Plex server to read the chapter timestamps correctly but this doesn’t help either.
Anyone else having this issue or know if a fix is coming ?
