OBSERVED BEHAVIOR
When playing a song on Plex for Android. I let the song play for half way then paused it.
I opened Local Plex Web App found the same song, in the same album, and pressed play.
Pay close attention to the play time of the song. You will see the time double.
It will however correct itself after the first time repeating.
As expected the song resumed for the half way point when it was paused on Plex for
Android. However, if you make the track repeat [“Repeat (1)”] the track will play to the end
and then repeat from the half way point it was originally paused at from Plex for
Android.
Trying to play the song back on Plex for Android results in the following error message:
“Streaming Session doesn’t exist or timed out.”
Same occurrence with the Plex Web App (non-Local).
DESIRED BEHAVIOR
The song should play from the beginning on repeat [“Repeat (1)”] and the time should
be displayed correctly.
AREA(S) AFFECTED
Plex Web App
Plex Media Server - Local Plex Web App
Plex for Android
Can someone try this out and see if they get the same result? Please and Thank you!
