So I had an issue a few weeks ago which resulted in me replacing a hard drive and then none of my dockers working. Got Synology support involved and they “fixed” it and got all my dockers working.
During the process I learnt more about Synology Log Centre and I’ve been keeping an eye on it.
Today I realised that none of my new media was being added to Plex, it hasn’t been since Monday.
In Log Centre I can see quite a few entries such as this: Checksum mismatch on file [/volume1/Plex/Library/Application Support/Plex Media Server/Metadata/TV Shows/b/e5028bd1e4a6259db1f00b8d5e66a71bd54375e.bundle/Contents/com.plexapp.agents.thetvdb/seasons/53/posters/1b429170d4a0094c45387e9eafd06a06455bcee3].
I’m up for reinstalling Plex if it has corrupted but I’d dearly love to keep my played states. Unfortuantley I think my backups have currupted as well but I’m just trying to look through my Azure storage blob to work out if I can get them.
What options do I have?
I’ve attached the Plex logs to this post. Any help would be much appriciated.
localhost/3/77337ac09a60482899b2e0563e9679e19fa0d74.bundle/Contents"
Mar 21, 2020 14:38:22.529 [0x7fb6bbfff700] DEBUG - There was a change for metadata item 14437 (Last Gold), saving.
Mar 21, 2020 14:38:22.529 [0x7fb6bbfff700] DEBUG - Updating metadata item (save) (Last Gold) with ID 14437
Mar 21, 2020 14:38:22.530 [0x7fb6bbfff700] ERROR - SQLITE3:(nil), 11, database corruption at line 64757 of [bf8c1b2b7a]
Mar 21, 2020 14:38:22.530 [0x7fb6bbfff700] ERROR - SQLITE3:(nil), 11, database corruption at line 64798 of [bf8c1b2b7a]
Mar 21, 2020 14:38:22.530 [0x7fb6bbfff700] ERROR - SQLITE3:(nil), 11, statement aborts at 250: [update metadata_items set library_section_id=:metadata_items_library_section_id,parent_id=:metadata_items_parent_id,metadata_type=:metadata_items_metadata_type,guid=:metadata_items_gu
Mar 21, 2020 14:38:22.530 [0x7fb6bbfff700] ERROR - Exception inside transaction (inside=1) (../Library/MetadataItem.cpp:1003): sqlite3_statement_backend::loadOne: database disk image is malformed
Mar 21, 2020 14:38:22.530 [0x7fb6bbfff700] ERROR - * Error loading episode.
Mar 21, 2020 14:38:22.540 [0x7fb6bbfff700] DEBUG - Loading season 1 fro
Thanks for the reply. I take it then that I should try to repair the corrupted DB using a backup if one exists and then I might be ok? I’ll give this a go in the morning and report back.
Thanks again, just followed the steps and all is working fine again. I’ll keep an eye on the checksum mismatch errors. Do you think this will resolve them or will I need to do some additional work?
