Server Version#: latest
Player Version#: latest
Hello
I have only one server, still plex insists i have two, the big problem is that my tv-seasons are missing episodes, but when i choose the other identical server the missing episodes reappear
Did you recently “clone” your server, as described in here? Move an Install to Another System | Plex Support
I have used the same system, but have copied the install directory from an (E:) ssd to the ssd containing the windows installation
Are you saying that you moved the server data to a completely different machine?
Or did you just move it from one hard drive to a different hard drive, within the same machine?
Second option, i moved the data between harddrives within the machine
I installed plex on my windows drive, but changed it (using regedit also) to another ssd within the machine
But after a while i saw that i didnt need a seperate ssd to store plex data, and moved everything back
Could you show a larger portion of the screen? I am unsure at which step this kind of selection dialogue is even appearing.
Thank you, that seems to have solved the problem <3
