Disappearing seasons
ive jsut noticed that some of my seasons are disappearing. ive got two servers, one shows all the seasons. but not on the other they are both the same gall episodes are named the same.
If i drag the files to a new drive they appear. but not on the original file, donr really want to move 2tb of files to another drive
Any ideas ?
Probably an aborted conversion to the new metadata agent?
Refresh Metadata of the whole library.
thanks ive tried that and its still only showing 3 seasons it was five, ive moved it to another drive and irs shown up instantly
Is the other drive connected to a different Plex library?
If so, maybe you have different agent settings between the two libraries?
Its the same libary, ive noticed its if something is added to the series the season/ epsidoes start to disappear. i was checking other series on that drive and i scanned folder and watch them disappear.
Moved to a new drive and it appears again
Please show the folder organization and your actual file names.
Betting its a naming schema issue, or needs a plex dance
