Server Version#: Version 1.32.6.7557
Player Version#: Chromecast Ultra FW: 1.56.281627
Hardware: Plex server, Chromecast Ultra (CCU), Ethernet connection, 2019 Toshiba LCD TV
Strange issue I cant figure out. Some HVEC (H.265) movies suffer really annoying stutter/jerkiness whilst watching, making them borderline unwatchable.
I suspect it’s a frame rate issue like skipping or unsynchronised frames.
The strange thing is some (seemingly identical) HVEC (H.265) media will play flawlessly whilst others suffer.
I’ve tried pretty much everything I can think of. It’s defiantly not connection speeds or any CCU/TV settings.
It’s almost as if the CCU isn’t adjusting the frame rate properly or Plex/Played media isn’t transferring the correct info to the CCU for it to set the frame rate properly.
Does anyone have any suggestions on the cause and if there’s a way to fix?
I’ve included working vs Non working media metadata (From Plex) below. They’re virtually identical but one will play perfectly whilst the other will not.
Example Media: Not Working = stutter/jerkiness
Duration 2:22:33
Bitrate 2223 kbps
Width 1920
Height 800
Aspect Ratio 2.35
Video Resolution 1080p
Container MP4
Video Frame Rate 24p
Web Optimized No
Audio Profile lc
Video Profile main 10
Part
File *****************1080p.BluRay.x265.mp4
Size 2.22 GB
Audio Profile lc
Container MP4
Web Optimized No
Codec HEVC
Bitrate 1999 kbps
Bit Depth 10
Chroma Location left
Chroma Subsampling 4:2:0
Codec ID hev1
Coded Height 800
Coded Width 1920
Color Range tv
Frame Rate 23.976 fps
Height 800
Level 4.0
Profile main 10
Ref Frames 1
Stream Identifier 1
Width 1920
Display Title 1080p (HEVC Main 10)
Extended Display Title 1080p (HEVC Main 10)
Codec AAC
Channels 6
Bitrate 224 kbps
Language English
Language Tag en
Audio Channel Layout 5.1
Profile lc
Sampling Rate 48000 Hz
Stream Identifier 2
Display Title English (AAC 5.1)
Extended Display Title English (AAC 5.1)
Example Media: Working = Plays flawlessly
Duration 1:36:48
Bitrate 2224 kbps
Width 1920
Height 800
Aspect Ratio 2.35
Container MP4
Web Optimized No
Audio Profile lc
Part
Duration 1:36:48
Size 1.51 GB
Audio Profile lc
Container MP4
Web Optimized No
Codec HEVC
Bitrate 2000 kbps
Bit Depth 10
Codec ID hev1
Coded Height 800
Coded Width 1920
Color Range tv
Height 800
Level 4.0
Profile main 10
Ref Frames 1
Stream Identifier 1
Width 1920
Codec AAC
Channels 6
Bitrate 224 kbps
Language English
Language Tag en
Profile lc
Stream Identifier 2
