Cinema trailers not working
macOS Big Sur RAM 8GB downlink 50Mbps Uplink 10Mbps
Cannot play trailers or extras since upgrading to beta: v.1.40.2.8351-9938371be
April 9, 2024
On local server Conversion failed. The transcoder exited due to an error.
Using HW transcoder never had problem before
Had to turn off “play X number of cinema trailers” to watch movies
Apr 12, 2024 10:09:53.750 [0x70000ac60000] ERROR - [Req#146/Transcode/sxmgdtfw21g3iiho3x1pnz3e/a2feba07-134e-4313-ba63-6fe2cb3868e7] http://127.0.0.1:32400/services/iva/assets/70394/video.mp4?fmt=4&bitrate=5000&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx: Server returned 5XX Server Error reply
Apr 12, 2024 10:10:00.020 [0x70000a2a7000] ERROR - [Req#15d/Transcode/sxmgdtfw21g3iiho3x1pnz3e/a2feba07-134e-4313-ba63-6fe2cb3868e7] http://127.0.0.1:32400/services/iva/assets/70394/video.mp4?fmt=4&bitrate=5000&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx: Server returned 5XX Server Error reply
Apr 12, 2024 10:10:00.533 [0x70000a2a7000] WARN - [Req#167/Transcode] Denying access to transcode of key /library/metadata/70345 due to terminated session
Apr 12, 2024 10:10:00.958 [0x70000abdd000] WARN - [Req#170] Invalid library metadata ID 5e4d2550f66fbd003e4d06b7 passed.
Apr 12, 2024 10:10:41.261 [0x70000ac60000] INFO - Request: [127.0.0.1:52619 (Loopback)] PUT /:/prefs?CinemaTrailersIncludeEnglish=0 (3 live) #182 GZIP Signed-in Token (paulhugel) (Safari)
Apr 12, 2024 10:10:41.446 [0x700009e8f000] INFO - Completed: [127.0.0.1:52619] 200 PUT /:/prefs?CinemaTrailersIncludeEnglish=0 (3 live) #182 GZIP 185ms 323 bytes (pipelined: 1)
Apr 12, 2024 10:11:54.653 [0x70000a09b000] WARN - [Req#1d0/Database optimization/com.plexapp.plugins.library.db/DatabaseFixups] Held transaction for too long (/System/Volumes/Data/data/actions-runner/_work/plex-media-server/plex-media-server/Library/DatabaseFixups.cpp:224): 0.170000 seconds
Apr 12, 2024 10:11:58.538 [0x70000a09b000] WARN - [Req#1d0/Database optimization/com.plexapp.plugins.library.db] Held transaction for too long (/System/Volumes/Data/data/actions-runner/_work/plex-media-server/plex-media-server/Library/FullTextSearch.cpp:58): 3.630000 seconds
Apr 12, 2024 10:12:01.009 [0x70000a09b000] WARN - [Req#1d0/Database optimization/com.plexapp.plugins.library.db] Held transaction for too long (/System/Volumes/Data/data/actions-runner/_work/plex-media-server/plex-media-server/Library/FullTextSearch.cpp:71): 1.960000 seconds
Apr 12, 2024 10:12:02.685 [0x70000a09b000] WARN - [Req#1d0/Database optimization/com.plexapp.plugins.library.db] Held transaction for too long (/System/Volumes/Data/data/actions-runner/_work/plex-media-server/plex-media-server/Library/FullTextSearch.cpp:81): 1.560000 seconds
Apr 12, 2024 10:12:04.452 [0x70000a09b000] WARN - [Req#1d0/Database optimization/com.plexapp.plugins.library.db] Held transaction for too long (/System/Volumes/Data/data/actions-runner/_work/plex-media-server/plex-media-server/Library/FullTextSearch.cpp:94): 1.640000 seconds
Apr 12, 2024 10:12:15.027 [0x70000a09b000] INFO - [Req#1d0/Database optimization/com.plexapp.plugins.library.db] SQLITE3:(nil), 17, statement aborts at 59: [select * from metadata_items limit 1] database schema has changed
Apr 12, 2024 10:12:15.029 [0x70000a09b000] INFO - [Req#1d0/Database optimization/com.plexapp.plugins.library.db] SQLITE3:(nil), 17, statement aborts at 59: [select * from metadata_items limit 1] database schema has changed
Apr 12, 2024 10:12:15.031 [0x70000a09b000] INFO - [Req#1d0/Database optimization/com.plexapp.plugins.library.db] SQLITE3:(nil), 17, statement aborts at 59: [select * from metadata_items limit 1] database schema has changed
Apr 12, 2024 10:12:15.033 [0x70000a09b000] INFO - [Req#1d0/Database optimization/com.plexapp.plugins.library.db] SQLITE3:(nil), 17, statement aborts at 59: [select * from metadata_items limit 1] database schema has changed
Apr 12, 2024 10:12:15.038 [0x70000a09b000] INFO - [Req#1d0/Database optimization/com.plexapp.plugins.library.db] SQLITE3:(nil), 17, statement aborts at 59: [select * from metadata_items limit 1] database schema has changed
Apr 12, 2024 10:12:15.041 [0x70000a09b000] INFO - [Req#1d0/Database optimization/com.plexapp.plugins.library.db] SQLITE3:(nil), 17, statement aborts at 59: [select * from metadata_items limit 1] database schema has changed
Apr 12, 2024 10:12:15.042 [0x70000a09b000] INFO - [Req#1d0/Database optimization/com.plexapp.plugins.library.db] SQLITE3:(nil), 17, statement aborts at 59: [select * from metadata_items limit 1] database schema has changed
Apr 12, 2024 10:12:15.044 [0x70000a09b000] INFO - [Req#1d0/Database optimization/com.plexapp.plugins.library.db] SQLITE3:(nil), 17, statement aborts at 59: [select * from metadata_items limit 1] database schema has changed
Apr 12, 2024 10:12:15.046 [0x70000a09b000] INFO - [Req#1d0/Database optimization/com.plexapp.plugins.library.db] SQLITE3:(nil), 17, statement aborts at 59: [select * from metadata_items limit 1] database schema has changed
Apr 12, 2024 10:12:15.047 [0x70000a09b000] INFO - [Req#1d0/Database optimization/com.plexapp.plugins.library.db] SQLITE3:(nil), 17, statement aborts at 59: [select * from metadata_items limit 1] database schema has changed
Apr 12, 2024 10:12:15.049 [0x70000a09b000] INFO - [Req#1d0/Database optimization/com.plexapp.plugins.library.db] SQLITE3:(nil), 17, statement aborts at 59: [select * from metadata_items limit 1] database schema has changed
Apr 12, 2024 10:12:15.050 [0x70000a09b000] INFO - [Req#1d0/Database optimization/com.plexapp.plugins.library.db] SQLITE3:(nil), 17, statement aborts at 59: [select * from metadata_items limit 1] database schema has changed
Apr 12, 2024 10:12:15.052 [0x70000a09b000] INFO - [Req#1d0/Database optimization/com.plexapp.plugins.library.db] SQLITE3:(nil), 17, statement aborts at 59: [select * from metadata_items limit 1] database schema has changed
Apr 12, 2024 10:12:15.054 [0x70000a09b000] INFO - [Req#1d0/Database optimization/com.plexapp.plugins.library.db] SQLITE3:(nil), 17, statement aborts at 59: [select * from metadata_items limit 1] database schema has changed
Apr 12, 2024 10:12:15.057 [0x70000a09b000] INFO - [Req#1d0/Database optimization/com.plexapp.plugins.library.db] SQLITE3:(nil), 17, statement aborts at 59: [select * from metadata_items limit 1] database schema has changed
Apr 12, 2024 10:12:15.059 [0x70000a09b000] INFO - [Req#1d0/Database optimization/com.plexapp.plugins.library.db] SQLITE3:(nil), 17, statement aborts at 59: [select * from metadata_items limit 1] database schema has changed
Apr 12, 2024 10:12:15.061 [0x70000a09b000] INFO - [Req#1d0/Database optimization/com.plexapp.plugins.library.db] SQLITE3:(nil), 17, statement aborts at 59: [select * from metadata_items limit 1] database schema has changed
Apr 12, 2024 10:12:15.062 [0x70000a09b000] INFO - [Req#1d0/Database optimization/com.plexapp.plugins.library.db] SQLITE3:(nil), 17, statement aborts at 59: [select * from metadata_items limit 1] database schema has changed
Apr 12, 2024 10:12:15.064 [0x70000a09b000] INFO - [Req#1d0/Database optimization/com.plexapp.plugins.library.db] SQLITE3:(nil), 17, statement aborts at 59: [select * from metadata_items limit 1] database schema has changed
Apr 12, 2024 10:13:51.313 [0x70000a536000] INFO - SQLITE3:(nil), 17, statement aborts at 29: [SELECT mts.id,mts.account_id,mts.guid,mts.rating,mts.view_offset,mts.view_count,mts.skip_count,mts.last_viewed_at,mts.last_skipped_at,mts.last_rated_at,mts.created_at,mts.updated_at,mts.extra_data,mts.changed_at FROM metadata_item_settings mts WHERE (mts.account_id=:C1 AND mts.guid=:C2)] database schema has changed
Apr 12, 2024 10:13:51.313 [0x70000a536000] INFO - SQLITE3:(nil), 17, statement aborts at 19: [SELECT sts.id,sts.account_id,sts.media_stream_id,sts.created_at,sts.updated_at,sts.extra_data FROM media_stream_settings sts WHERE (sts.account_id=:C1 AND sts.media_stream_id=:C2)] database schema has changed
Apr 12, 2024 10:13:57.047 [0x70000a11e000] ERROR - [Req#239/Transcode/w7tjjrsplx73a08493g856ai/95b3dbb7-c316-4d19-9e4c-8804ec7f3f0b] http://127.0.0.1:32400/services/iva/assets/70394/video.mp4?fmt=4&bitrate=5000&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx: Server returned 5XX Server Error reply
Apr 12, 2024 10:14:06.598 [0x70000a11e000] ERROR - [Req#24e/Transcode/w7tjjrsplx73a08493g856ai/95b3dbb7-c316-4d19-9e4c-8804ec7f3f0b] http://127.0.0.1:32400/services/iva/assets/70394/video.mp4?fmt=4&bitrate=5000&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx: Server returned 5XX Server Error reply
Apr 12, 2024 10:14:06.982 [0x7000098ee000] WARN - [Req#258/Transcode] Denying access to transcode of key /library/metadata/70345 due to terminated session
Apr 12, 2024 10:14:07.362 [0x70000a11e000] WARN - [Req#265] Invalid library metadata ID 5e4d2550f66fbd003e4d06b7 passed.
Can you grab the roku logs after trying to play one on it.
I am having the same issue. I don’t use the cinema trailers. Mine are just the automatically found extras for a movie. I get the conversion failed. The Transcoder exited due to an error, error. They all worked two days ago and today nothing. If I restart the Plex server, I will get one trailer before I get the error.
Any help or suggestions would be appreciated.
I am having the same issue too since I install the last version.
I hope that in the next version this error will be corrected…
Thanks to everyone for your kind remarks. I got the service back by disabling watching trailers. I am really frustrated. As I said before, years ago I lost the ability of watching new trailers. No one could help me to regain access to them. And now, I am loosing the possibility of watching trailers of my own movies. I hope we get the whole service back very soon.
This has been happening to many people all of sudden, me included, across two servers. It is a ‘server’ issue, not a ‘client’ issue.
If you do a time-sync on the server, it will fix the issue for some small period of time, but it will happen again. Not sure what changed to cause this, but it is very frustrating.
Just to add this here, at least for Windows, you can fix this (temporarily) by doing a time-sync on the server. If you do that, trailers will immediately begin to work, although some short time later they will stop again. (Until you do another time-sync).
The trailer issue just started happening to many people. On Windows, at least, if you do a time-sync, the trailers will start working again immediately. A short time later (I do not know how long), it will start to fail again. (Until you do another time-sync).
You can try that to see if it temporarily resolves your trailer issue. My guess is we’re all dealing with the same bug around time-sync.
Server Version#: 1.40.1.8227
Player Version#: 8.34
Apr 10, 2024 21:08:29.403 [139647323745080] ERROR - [Req#13089/Transcode/69AA59D2-3D3E-4023-B9EF-8FDFE4C5C1CF/92e228ab-502c-4a76-a97f-1b601073c932] http://127.0.0.1:32400/services/iva/assets/703881/video.mp4?fmt=4&bitrate=5000&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx: Server returned 5XX Server Error reply
Apr 10, 2024 21:08:34.610 [139647273413432] WARN - [Req#13130/Transcode] Got a request to stop a transcode session without a valid session GUID.
If I restart PMS it will work a few times and then stop.
I’ve moved all these into a single topic
I was curious if y’all go to https://watch.plex.tv/ and watch a trailer of something there, does it also fail?
Same issue for me. This is so frustrating.
On watch.plex.tv they work for me.
MacBook Pro 2019 on Safari 17.4.1 and macOS Sonoma 14.4.1 (23E224)
I have the same error code “Server returned 5XX Server Error” when I try to watch a trailer with my Roku, iPhone, Mac OS and Apple TV!
Yes, it fails.
I can’t.
Playing from https://watch.plex.tv/, trailers do in fact work. Playing localy, they do not.
Hi, they don’t play in my computer or on my Apple TV. What does “playing locally” mean? Thanks.
Seems to be a CORS issue:
Access to XMLHttpRequest at ‘https://1-2-3-4.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.plex.direct:32400/video/:/transcode/universal/session/8fbklgb8rjdk2444gbocqi/base/00000.ts’ from origin ‘https://my.domain:32400’ has been blocked by CORS policy: The ‘Access-Control-Allow-Origin’ header has a value ‘https://app.plex.tv’ that is not equal to the supplied origin.
A TEMPORARY fix for those who need their trailer fix and are using browser: See Temporary solution from browser side:
“Playing Locally” = Playing direct from\on your Plex server.
