Cleaning empty age rating filter
Server Version#: 1.25.3.5385
Player Version#: Plex Web 4.69.1
Some age rating filter items didn’t disappear if the filter has no results.
I have dozens of empty age rating filter items like “AB 0 JAHREN”, “ab 0 Jahren”, “FSK0”… (the real filter value ist “Ab 0 Jahren”…
Is there a way to remove this many empty filter values? I tried to clean web caches and database etc…
All other filter values like genre etc. works perfect (is no more entry for a filter value, the value disappear.)
Usually those will go away if you reload the web app and the value is no longer in any of your movies.
In case you want to be able to use it with restriction profiles (e.g. when sharing with kids/teens in your home), the nomenclature is either 0 or de/0 (which will be displayed as 0).
That’s the point. USUALLY those go away. And many items of them disappear when they are empty. But a dozen are persistent (and empty) and I had no idea where I can fix/refresh it.
The restriction profiles works great… but there are all the empty wrong items too. So you have to remember what are the correct items.
