Has this happened to anyone else? I can’t seem to return the movie clip arts to the correct size? Any help would be appreciated!
vs. how it usually looks
You have set the agent to “Personal Media”. Return it to one of the other options.
Appreciate you!!
I started messing with those settings after it didn’t detect all the videos. Last question, is there a way to force the previously added videos back on that it doesn’t want to recognize?
Not sure what you 're asking, but failure to recognize items is usually down to naming issues.
https://support.plex.tv/articles/201543057-why-is-some-of-my-content-not-found/
Did something change recently causing the agent to not be able to find the movies with numbers in the title? 33, 42, 71, 300, 1917.
Actual file names, please.
Those are the actual movie/file names.
