Cloud Sync Question
This is more of a dev side question, not sure if anyone here can answer it, but I’m a software developer so I’m curious. Why is it that the cloud sync hangs so much on “waiting to upload”? This should be a relatively simple operation. You’re transcoding the source file into a copy on disk… Simple enough. Then you should just be doing a “put” similar to as you would to an AWS S3 bucket, uploading that file to the cloud service. This should only be limited by upload speed, so I’m really not sure what it says it’s “waiting” for. I realize this is kind of a question about what’s going on behind the scenes, but again, I am just curious.
Thanks in advance.
—bump—
—bump—
Have you examined your plex media server.log?
The logs will generally show what decisions are made during the process
REF: https://support.plex.tv/hc/en-us/articles/200250417-Plex-Media-Server-Log-Files
