Collection help
how do I force Plex to scan my movies and create collections?
I think I have it turned on and there is 34 collections, but I have thousands of movies and many should be in collections.
but I thought there was a setting to have plex automatically create collections?
If you’re using the Plex Movie (non-legacy) agent, make sure the following is not disabled in your library’s advanced configuration tab:
If you change this setting, make sure to refresh all metadata for your library. And mind the note in the description: This doesn’t affect existing collections.
