Hello!
Server Version#: 1.25.2.5319-7000
Player Version#: Plex Web 4.66.1 (pc with w10),
i.e., http://192.168.1.150:32400/web/index.html#!/media/…
Problem:
Tab “Collections” does not display properly the collections,
but instead gives the same result as the tab “Library” (plus embedded Collections)
Formerly, it worked properly.
The new behavior occurred since I upgraded my Synology NAS from SHR to SHR2 (and adding 5 HDDs).
Note that the windows app 1.39.1.2763-300bb607 still displays properly the collections
Thanks for help.
- Open Plex Web
- Navigate to
Settings>Plex Web>Debug - Click
Restore Defaults— this will reset the Plex Web configuration and customizations; your server isn’t impacted - Reload the web app
Problem fixed!
Thanks!
