Collections not working
Hi all, I’m sure this is a simple question and hopefully simpler fix. I have 2500 movies and many should be part of a collection. For some reason I have just 5 movies in collections. How do I get all my movies in collections?
Thanks in advance.
Gary
https://support.plex.tv/articles/201273953-collections/
You can’t get all your movies into collections. At least not automatically.
The automatic collections use data from TheMovieDB.org. And this website only allows direct sequels and prequels to be in a collection together.
Thanks for that I get it. But I have thousands of movies with many prequels/sequels but they are not populating the collections tab! Any ideas?
Which metadata agent is selected in the properties of the library?
On the “Advanced” tab, is there a selector titled “Minimum automatic collection size” and what is it set to?
