On Apple devices, Plex (only) supports DV P5 via Direct Play to the Apple player.
So MP4 matters because the Apple player supports it.
But this ignores the fact that other players (Infuse, VLC) can play it using the MKV container and that previous versions of Plex server continue to support playing these files.
There’s no way this is a licensing issue. Licenses don’t work that way. You can’t distribute binaries or code without license checks. If it was causing problems with new releases, it would be doing the same for all releases.
And even if it were, do you think Firecore is outdoing Plex? Given their relative sizes, I just can’t believe Firecore has this working and Plex doesn’t. It’s absolutely a priority issue.
So while I’m posting, I’ll make it further clear for Plex what the issue is. Files like this don’t play at all in 1.26.2.5797:
Additionally, I did experiment with using the MP4 container and it will try to play, but only gets audio correct. The player is just black with a spinning loader.
People are right to be mad because there’s no answer or roadmap to an answer.
Don’t get me wrong, this is my first real issue with Plex, but the responses here leave much to be desired. I don’t need a fixed version at the moment, but I’d like to know when to expect it. The solution for an issue with Plex shouldn’t be to install another player.
Still looking into this and it seems like some files are not remuxing when they should (I had incorrect info before when i said a direct stream won’t work, it should)
This is actually an interesting point. The error says it’s attempting a transcode, but I’ve configured my server to use Direct Play. Switching to the “old” video player on the tvOS app will produce a black screen with a loading wheel as well and the details show it as Direct Play, but it doesn’t work.
I would have no problem if I could Direct Play these files, but not transcode. Transcoding issues are understood on my end.
Do you have any advice to force it to not transcode?
You can disable video transcoding in server settings but if the client specifically request a transcode because it thinks it cannot play otherwise it won’t help.
A remux (direct stream) is a transcode in that the transcoder is what does the remuxing. The info i have is that for the colors to be correct for Apple TV it needs to remux out of an Mkv because it needs to use apples avplayer, instead of mpv which would not get the colors right.
One things I was going to ask if you still have a copy of older server you said works, is to install that and play the file and grab the server and client logs. Then upgrade the server to current where it is not working reproduce and grab those server and client logs.
Hopefully devs will be able to determine what is different. If you need a copy of older server let me know I might be able to get a copy
We know Plex has other agreements with Dolby and incorporates Dolby-provided components.
So it’s possible Plex has agreed to never do anything “unauthorized” related to Dolby tech. I dunno! I’m not trying to argue about how things “should” be.
Edit: Just a note that I don’t have any conspiracy theory. Licensing agreements are complicated.
If they’re MP4, dvh1 HEVC DV P5 does for me.
Can you share your commands and the output?
Partly because I’d like to help you; partly because I’d like to further validate the technique I’m using.
So is there possibly a mistake in this error as well? If it’s just a remux, then the video codec and audio codec aren’t being modified and the NAS device could probably handle it. I’ve used ffmpeg and mkvmerge before to re-containerize media and it’s always very low resource.
I’d love a sample file that last worked in 1.25.4.5487. If somebody gets those logs for @BigWheel please share a sample file too!
Because … I can’t find anything that worked in 1.25.4.5487 but doesn’t work in 1.26.2.5797.
Using Chrome to access Plex Web on PMS 1.25.4.5487, HEVC DV P5 videos are transcoded but not tone-mapped. Plex isn’t aware of the colorspace and the colors are very wrong.
Using Chrome to access Plex Web on PMS 1.26.2.5797, HEVC DV P5 videos don’t play, and get the expected message: Playback Error: File is unplayable. Color space is not supported.
Both PMS versions behave similarly from an Apple TV 4K or a Roku TV. Neither works with MKV. The Roku works with TS. The Roku is more tolerant of MP4 flavors. The Apple TV works with MP4 dvh1.
You didn’t link the wrong one. I just skipped that you linked it and went off searching for it on my own. That’s my mistake.
I’m now running these steps for all my DV files and I’ll keep an eye out here. If there’s any additional help I can provide on the files that weren’t working, let me know.
Sorry for confusion. I only meant the transcoder does the remuxing which would show as a direct stream. It is failing at that for some reason and giving the error that the reason is the colorspace is not supported.
I can’t say when they will figure out a fix. The devs are investigating and as I get info i will let you know. I apologize for having incorrect info previously
I ended up throwing this together today because it worked well for me. It’s just a script that should make conversion of files easier those who wish to try this method in the future.
Still feels like a bit of a workaround, but the reason for the issue does make sense to me now.
