Dolby Vision stopped working on LG OLED65C7D
Server Version#: 1.28.0.5999-97678ded3
Player Version#: 5.43.2
Dolby Vision stopped working suddenly in the last week or so. I tried with older server versions too, still getting “File is unplayable. Color space is not supported.”.
Will the fix for the newer models also get released for the older models?
Thanks.
Edit: Here are the logs:
Aug 06, 2022 10:19:42.858 [0x7fd48fa8eb38] INFO - [Req#14e5] [Plex for LG] [TuncTaylan:jzvegotojipv6lxrtx6gbga2] [LogToPmsManager] Now logging to server
Aug 06, 2022 10:19:57.433 [0x7fd48fa8eb38] ERROR - [Req#150b/Transcode] Streaming Resource: Cannot make a decision because either the file is unplayable or the client provided bad data
Aug 06, 2022 10:19:57.745 [0x7fd48fa8eb38] INFO - [Req#150e] [Plex for LG] [TuncTaylan:jzvegotojipv6lxrtx6gbga2] Navigating to screen: PreplayScreen
Aug 06, 2022 10:19:57.745 [0x7fd48fa8eb38] INFO - [Req#150e] [Plex for LG] [TuncTaylan:jzvegotojipv6lxrtx6gbga2] Navigated to screen: PreplayScreen
Aug 06, 2022 10:19:57.745 [0x7fd48fa8eb38] INFO - [Req#150e] [Plex for LG] [TuncTaylan:jzvegotojipv6lxrtx6gbga2] Navigating to screen: VisualMediaPlaybackScreen
Aug 06, 2022 10:19:57.745 [0x7fd48fa8eb38] WARN - [Req#150e] [Plex for LG] [TuncTaylan:jzvegotojipv6lxrtx6gbga2] themeChanged is not defined for @autoCallback property: themeOverride
Aug 06, 2022 10:19:57.745 [0x7fd48fa8eb38] INFO - [Req#150e] [Plex for LG] [TuncTaylan:jzvegotojipv6lxrtx6gbga2] Navigated to screen: VisualMediaPlaybackScreen
Aug 06, 2022 10:19:57.745 [0x7fd48fa8eb38] INFO - [Req#150e] [Plex for LG] [TuncTaylan:jzvegotojipv6lxrtx6gbga2] [PlaybackMetrics] Attaching playback metrics to PlayerController
Aug 06, 2022 10:19:57.745 [0x7fd48fa8eb38] INFO - [Req#150e] [Plex for LG] [TuncTaylan:jzvegotojipv6lxrtx6gbga2] [SubtitleConnectionManager] Subtitle connection ignored. App is not rendering subtitles.
Aug 06, 2022 10:19:57.745 [0x7fd48fa8eb38] INFO - [Req#150e] [Plex for LG] [TuncTaylan:jzvegotojipv6lxrtx6gbga2] [ServerConnectionTestManager] Stopped
Aug 06, 2022 10:19:57.745 [0x7fd48fa8eb38] WARN - [Req#150e] [Plex for LG] [TuncTaylan:jzvegotojipv6lxrtx6gbga2] _onOnPlayPauseInvokedChanged is not defined for @autoCallback property: onPlayPauseInvoked
Aug 06, 2022 10:19:57.745 [0x7fd48fa8eb38] INFO - [Req#150e] [Plex for LG] [TuncTaylan:jzvegotojipv6lxrtx6gbga2] [MDE] Application decision, directPlay: false, directStreamVideo: false, directStreamAudio: true
Aug 06, 2022 10:19:57.745 [0x7fd48fa8eb38] INFO - [Req#150e] [Plex for LG] [TuncTaylan:jzvegotojipv6lxrtx6gbga2]     Cannot direct play with protocol: http, codec: hevc. Reason: Dolby Vision Profile 5 is not supported
Aug 06, 2022 10:19:57.745 [0x7fd48fa8eb38] INFO - [Req#150e] [Plex for LG] [TuncTaylan:jzvegotojipv6lxrtx6gbga2]     Cannot direct stream with protocol: hls, codec: hevc. Reason: Dolby Vision Profile 5 is not supported
Aug 06, 2022 10:19:57.745 [0x7fd48fa8eb38] INFO - [Req#150e] [Plex for LG] [TuncTaylan:jzvegotojipv6lxrtx6gbga2]   videoStream: {
  "id": 166088,
  "streamType": 1,
  "default": true,
  "codec": "hevc",
  "index": 1,
  "bitrate": 16476,
  "DOVIBLCompatID": 0,
  "DOVIBLPresent": true,
  "DOVIELPresent": false,
  "DOVILevel": 6,
  "DOVIPresent": true,
  "DOVIProfile": 5,
  "DOVIRPUPresent": true,
  "DOVIVersion": "1.0",
  "bitDepth": 10,
  "chromaLocation": "left",
  "chromaSubsampling": "4:2:0",
  "codecID": "dvhe",
  "codedHeight": 2160,
  "codedWidth": 3840,
  "colorRange": "pc",
  "frameRate": 24,
  "height": 2160,
  "level": 150,
  "profile": "main 10",
  "refFrames": 1,
  "streamIdentifier": "1",
  "width": 3840,
  "displayTitle": "4K DoVi (HEVC Main 10)",
  "extendedDisplayTitle": "4K DoVi (HEVC Main 10)"
Aug 06, 2022 10:19:57.745 [0x7fd48fa8eb38] INFO - [Req#150e] [Plex for LG] [TuncTaylan:jzvegotojipv6lxrtx6gbga2]   audioStream: {
  "id": 166087,
  "streamType": 2,
  "selected": true,
  "default": true,
  "codec": "eac3",
  "index": 0,
  "channels": 6,
  "bitrate": 768,
  "language": "İngilizce",
  "languageTag": "en",
  "languageCode": "eng",
  "audioChannelLayout": "5.1(side)",
  "samplingRate": 48000,
  "streamIdentifier": "2",
  "displayTitle": "İngilizce (EAC3 5.1)",
  "extendedDisplayTitle": "İngilizce (EAC3 5.1)"
Aug 06, 2022 10:19:57.745 [0x7fd48fa8eb38] INFO - [Req#150e] [Plex for LG] [TuncTaylan:jzvegotojipv6lxrtx6gbga2]   subtitleStream: {
  "id": 166115,
  "streamType": 3,
  "selected": true,
  "default": true,
  "codec": "mov_text",
  "index": 28,
  "bitrate": 0,
  "language": "Türkçe",
  "languageTag": "tr",
  "languageCode": "tur",
  "streamIdentifier": "29",
  "displayTitle": "Türkçe (MOV_TEXT)",
  "extendedDisplayTitle": "Türkçe (MOV_TEXT)"
Aug 06, 2022 10:19:57.745 [0x7fd48fa8eb38] INFO - [Req#150e] [Plex for LG] [TuncTaylan:jzvegotojipv6lxrtx6gbga2] Forcing subtitle burn: HLS direct stream incompatible
Aug 06, 2022 10:19:57.745 [0x7fd48fa8eb38] INFO - [Req#150e] [Plex for LG] [TuncTaylan:jzvegotojipv6lxrtx6gbga2] Cannot direct play subtitles. Reason: Server required to burn subtitles
Aug 06, 2022 10:19:57.745 [0x7fd48fa8eb38] WARN - [Req#150e] [Plex for LG] [TuncTaylan:jzvegotojipv6lxrtx6gbga2] Failed to create and set current playable media item - File is unplayable. Color space is not supported.
Aug 06, 2022 10:19:57.745 [0x7fd48fa8eb38] WARN - [Req#150e] [Plex for LG] [TuncTaylan:jzvegotojipv6lxrtx6gbga2] [PlaybackSessionController] we failed to create a playable URL!
Aug 06, 2022 10:19:57.745 [0x7fd48fa8eb38] ERROR - [Req#150e] [Plex for LG] [TuncTaylan:jzvegotojipv6lxrtx6gbga2] Playback error occurred. Reason: FailedToCreatePlayable, Failed to create a playable with the current play queue item! Message: File is unplayable. Color space is not supported.
Aug 06, 2022 10:19:57.745 [0x7fd48fa8eb38] WARN - [Req#150e] [Plex for LG] [TuncTaylan:jzvegotojipv6lxrtx6gbga2] [PlaybackSessionController] could not retry, reporting error
Aug 06, 2022 10:19:57.745 [0x7fd48fa8eb38] WARN - [Req#150e] [Plex for LG] [TuncTaylan:jzvegotojipv6lxrtx6gbga2] [PlaybackMetrics] Player sent ready signal or closed but no player or playable provided!
Aug 06, 2022 10:19:57.745 [0x7fd48fa8eb38] INFO - [Req#150e] [Plex for LG] [TuncTaylan:jzvegotojipv6lxrtx6gbga2] Opening modal: ActionsModal
Aug 06, 2022 10:19:57.745 [0x7fd48fa8eb38] INFO - [Req#150e] [Plex for LG] [TuncTaylan:jzvegotojipv6lxrtx6gbga2] Opened modal: ActionsModal
Edit2: correct player version, it is still not working.
The problem is with Dolby Vision profile 5 media, which does not have a HDR10 compatibility layer.
The same thing is happening with B7 models.
5.43.2 does not fix the problem on B7s.
I probably didn’t get you. That doesn’t make much sense to me otherwise.
The media didn’t change, it is the same file. It worked fine up until one or two weeks.
Is there any “official” statement about this issue?
I do not know why Dolby Vision profile 5 stopped working.
Just suggesting you may want to follow the B7 thread, since the problem is affecting more than just B7 models.
The other thread has Plex employee participation, so should have up to date info on progress towards a fix.
Please turn on debug logging on your server. Then enable logging in the app, reproduce the issue, grab the server logs. Also provide the xml info for the video you played.
Sure, here are the logs of the movie “Prey” I tried to play:
Probably the relevant part:
Edit: See this post for the logs
Here is the xml info of that movie:
Prey.xml.zip (6.5 KB)
Here are the logs of a second movie, which I definitely watched in DV via Plex a while ago:
Edit: See this post for the logs:
and the xml info of that movie:
Matrix.xml.zip (9.0 KB)
Edit: Before you ask, yes the direct play is enabled on the client.
Edit2: Sorry I forget the logs from the client, I’ll be back in 2-3 Minutes.
Edit3: Removed the older logs, the newest log files with the client logs is here in this post:
Here are the complete debug logs from the client as well (prey):
Aug 09, 2022 20:43:16.855 [0x7f8a8126fb38] DEBUG - Completed: [10.0.0.36:46866] 200 POST /log (9 live) GZIP 0ms 320 bytes (pipelined: 4)
Aug 09, 2022 20:43:24.183 [0x7f8a8004bb38] DEBUG - Request: [10.0.0.36:46866 (Subnet)] POST /playQueues?own=1&excludeElements=Actor%2CCollection%2CCountry%2CDirector%2CGenre%2CLabel%2CMood%2CPart%2CProducer%2CRole%2CSimilar%2CWriter%2CPhoto&excludeFields=file%2Ctagline&uri=server%3A%2F%2Ff29069d1ce4a9c2e401c3e13122d03586d9523cc%2Fcom.plexapp.plugins.library%2Flibrary%2Fmetadata%2F27408&type=video&continuous=0&includeRelated=0&shuffle=0&repeat=0&extrasPrefixCount=0 (9 live) #912 GZIP Signed-in Token (TuncTaylan) (LG OLED65C7D-Z)
Aug 09, 2022 20:43:24.183 [0x7f8a8004bb38] DEBUG - [Req#912] PlayQueue: Converted 'server://f29069d1ce4a9c2e401c3e13122d03586d9523cc/com.plexapp.plugins.library/library/metadata/27408' to 'library://x/item/%2Flibrary%2Fmetadata%2F27408'
Aug 09, 2022 20:43:24.183 [0x7f8a8004bb38] DEBUG - [Req#912] PlayQueue: 0 generated IDs compressed down to a 20 byte blob.
Aug 09, 2022 20:43:24.184 [0x7f8a8004bb38] DEBUG - [Req#912] PlayQueue: Start index: 0 End index: 0 Count: 1
Aug 09, 2022 20:43:24.184 [0x7f8a8004bb38] DEBUG - [Req#912] PlayQueue: 1 generated IDs compressed down to a 24 byte blob.
Aug 09, 2022 20:43:24.184 [0x7f8a8004bb38] DEBUG - [Req#912] PlayQueue: Added 1 items in 0.0 sec.
Aug 09, 2022 20:43:24.208 [0x7f8a8004bb38] DEBUG - [Req#912] Extras: Looking for extras for item plex://movie/5f409b43c63b480040eed75f with unwatched: 0 fromLibrary: 1 fromTheater: 0 fromBluray: 0 and preroll count: 0.
Aug 09, 2022 20:43:24.208 [0x7f8a8004bb38] DEBUG - [Req#912] Extras: Using allowable content ratings: , NC-17, NR, PG-13, R.
Aug 09, 2022 20:43:24.208 [0x7f8a8004bb38] DEBUG - [Req#912] Extras: Using genres: Action, Drama.
Aug 09, 2022 20:43:24.208 [0x7f8a8004bb38] DEBUG - [Req#912] Extras: Found 0 extras from library.
Aug 09, 2022 20:43:24.212 [0x7f8a8126fb38] DEBUG - Completed: [10.0.0.36:46866] 200 POST /playQueues?own=1&excludeElements=Actor%2CCollection%2CCountry%2CDirector%2CGenre%2CLabel%2CMood%2CPart%2CProducer%2CRole%2CSimilar%2CWriter%2CPhoto&excludeFields=file%2Ctagline&uri=server%3A%2F%2Ff29069d1ce4a9c2e401c3e13122d03586d9523cc%2Fcom.plexapp.plugins.library%2Flibrary%2Fmetadata%2F27408&type=video&continuous=0&includeRelated=0&shuffle=0&repeat=0&extrasPrefixCount=0 (9 live) GZIP 28ms 1404 bytes (pipelined: 5)
Aug 09, 2022 20:43:24.422 [0x7f8a7ff1bb38] DEBUG - Request: [10.0.0.36:46866 (Subnet)] GET /library/metadata/27408?checkFiles=1&includeChapters=1&includeMarkers=1 (9 live) #915 GZIP Signed-in Token (TuncTaylan) (LG OLED65C7D-Z)
Aug 09, 2022 20:43:24.428 [0x7f8a7ff1bb38] DEBUG - [Req#915] We're going to try to auto-select an audio stream for account 1.
Aug 09, 2022 20:43:24.428 [0x7f8a7ff1bb38] DEBUG - [Req#915] Selecting best audio stream for part ID 64946 (autoselect: 1 language: en)
Aug 09, 2022 20:43:24.428 [0x7f8a7ff1bb38] DEBUG - [Req#915] Audio Stream: 166087, Subtitle Stream: 0
Aug 09, 2022 20:43:24.430 [0x7f8a81292b38] DEBUG - Completed: [10.0.0.36:46866] 200 GET /library/metadata/27408?checkFiles=1&includeChapters=1&includeMarkers=1 (9 live) GZIP 7ms 4181 bytes (pipelined: 6)
Aug 09, 2022 20:43:24.599 [0x7f8a7fd14b38] DEBUG - Request: [10.0.0.36:46866 (Subnet)] GET /video/:/transcode/universal/decision?directPlay=0&directStream=0&directStreamAudio=1&protocol=hls&fastSeek=1&path=%2Flibrary%2Fmetadata%2F27408&session=dcuewllzllwka9k9v5dbijcf&mediaIndex=0&partIndex=0&mediaBufferSize=50000&hasMDE=1&subtitleSize=100&videoQuality=100&videoResolution=3840x2160&audioBoost=100&location=lan (9 live) #916 GZIP Signed-in Token (TuncTaylan) (LG OLED65C7D-Z)
Aug 09, 2022 20:43:24.599 [0x7f8a7fd14b38] DEBUG - [Req#916/Transcode] Found session GUID of dcuewllzllwka9k9v5dbijcf in session start.
Aug 09, 2022 20:43:24.599 [0x7f8a7fd14b38] DEBUG - [Req#916/Transcode] TranscodeUniversalRequest: adapting profile with augmentation data: add-transcode-target(type=videoProfile&context=streaming&protocol=hls&container=mpegts&videoCodec=h264,hevc,mpeg2video,mpeg4&audioCodec=aac,ac3,eac3,mp2,mp3)+add-limitation(scope=videoAudioCodec&scopeName=mp2&type=upperBound&name=audio.bitrate&value=350)+add-limitation(scope=videoAudioCodec&scopeName=mp3&type=upperBound&name=audio.bitrate&value=350)+add-limitation(scope=videoCodec&scopeName=h264&type=upperBound&name=video.level&value=51)+add-limitation(scope=videoTranscodeTarget&scopeName=h264&scopeType=videoCodec&context=streaming&protocol=hls&type=upperBound&name=video.bitDepth&value=8)+add-limitation(scope=videoTranscodeTarget&scopeName=h264&scopeType=videoCodec&context=streaming&protocol=hls&type=upperBound&name=video.width&value=3840)+add-limitation(scope=videoTranscodeTarget&scopeName=h264&scopeType=videoCodec&context=streaming&protocol=hls&type=upperBound&name=video.height&value=2160)+add-limitation(scope=videoTranscodeTarget&scopeName=hevc&scopeType=videoCodec&context=streaming&protocol=hls&type=upperBound&name=video.bitDepth&value=10)+add-limitation(scope=videoTranscodeTarget&scopeName=hevc&scopeType=videoCodec&context=streaming&protocol=hls&type=upperBound&name=video.width&value=3840)+add-limitation(scope=videoTranscodeTarget&scopeName=hevc&scopeType=videoCodec&context=streaming&protocol=hls&type=upperBound&name=video.height&value=2160)+add-limitation(scope=videoCodec&scopeName=hevc&type=notMatch&name=video.DOVIProfile&value=5)+add-limitation(scope=videoTranscodeTarget&scopeName=mpeg2video&scopeType=videoCodec&context=streaming&protocol=hls&type=upperBound&name=video.bitDepth&value=8)+add-limitation(scope=videoTranscodeTarget&scopeName=mpeg2video&scopeType=videoCodec&context=streaming&protocol=hls&type=upperBound&name=video.width&value=1920)+add-limitation(scope=videoTranscodeTarget&scopeName=mpeg2video&scopeType=videoCodec&context=streaming&protocol=hls&type=upperBound&name=video.height&value=1080)+add-limitation(scope=videoTranscodeTarget&scopeName=mpeg4&scopeType=videoCodec&context=streaming&protocol=hls&type=upperBound&name=video.bitDepth&value=8)+add-limitation(scope=videoTranscodeTarget&scopeName=mpeg4&scopeType=videoCodec&context=streaming&protocol=hls&type=upperBound&name=video.width&value=1920)+add-limitation(scope=videoTranscodeTarget&scopeName=mpeg4&scopeType=videoCodec&context=streaming&protocol=hls&type=upperBound&name=video.height&value=1080)
Aug 09, 2022 20:43:24.600 [0x7f8a7fd14b38] DEBUG - [Req#916/Transcode] TranscodeUniversalRequest: using augmented profile Generic
Aug 09, 2022 20:43:24.600 [0x7f8a7fd14b38] DEBUG - [Req#916/Transcode] Downloading document http://127.0.0.1:32400/library/metadata/27408?includeBandwidths=1&offset=-1&X-Plex-Incomplete-Segments=1&X-Plex-Session-Identifier=jo35gny9rltyb9sh25uwaed4
Aug 09, 2022 20:43:24.605 [0x7f8a7fd14b38] DEBUG - [Req#916/Transcode/Req#917] We're going to try to auto-select an audio stream for account 1.
Aug 09, 2022 20:43:24.605 [0x7f8a7fd14b38] DEBUG - [Req#916/Transcode/Req#917] Selecting best audio stream for part ID 64946 (autoselect: 1 language: en)
Aug 09, 2022 20:43:24.605 [0x7f8a7fd14b38] DEBUG - [Req#916/Transcode/Req#917] Audio Stream: 166087, Subtitle Stream: 0
Aug 09, 2022 20:43:24.607 [0x7f8a7fd14b38] DEBUG - [Req#916/Transcode] MDE: Selected protocol hls; container: mpegts
Aug 09, 2022 20:43:24.607 [0x7f8a7fd14b38] DEBUG - [Req#916/Transcode] MDE: analyzing media item 64917
Aug 09, 2022 20:43:24.607 [0x7f8a7fd14b38] DEBUG - [Req#916/Transcode] MDE: Prey (2022): Direct Play is disabled
Aug 09, 2022 20:43:24.607 [0x7f8a7fd14b38] DEBUG - [Req#916/Transcode] MDE: Prey (2022): media must be transcoded in order to use the hls protocol
Aug 09, 2022 20:43:24.607 [0x7f8a7fd14b38] DEBUG - [Req#916/Transcode] MDE: Prey (2022): no direct play video profile exists for http/mp4/hevc
Aug 09, 2022 20:43:24.607 [0x7f8a7fd14b38] DEBUG - [Req#916/Transcode] MDE: Prey (2022): no direct play video profile exists for http/mp4/hevc/eac3
Aug 09, 2022 20:43:24.607 [0x7f8a7fd14b38] DEBUG - [Req#916/Transcode] Prey - video.DOVIProfile limitation applies: 5 == 5
Aug 09, 2022 20:43:24.607 [0x7f8a7fd14b38] DEBUG - [Req#916/Transcode] MDE: Prey (2022): Direct Streaming is disabled, so video stream will be transcoded
Aug 09, 2022 20:43:24.607 [0x7f8a7fd14b38] DEBUG - [Req#916/Transcode] MDE: Prey (2022): no remuxable profile found, so video stream will be transcoded
Aug 09, 2022 20:43:24.607 [0x7f8a7fd14b38] DEBUG - [Req#916/Transcode] MDE: Cannot direct stream video stream due to profile or setting limitations
Aug 09, 2022 20:43:24.607 [0x7f8a7fd14b38] DEBUG - [Req#916/Transcode] MDE: Prey (2022): selected media 0 / 64917
Aug 09, 2022 20:43:24.607 [0x7f8a7fd14b38] ERROR - [Req#916/Transcode] Streaming Resource: Cannot make a decision because either the file is unplayable or the client provided bad data
Aug 09, 2022 20:43:24.607 [0x7f8a7fd14b38] DEBUG - [Req#916/Transcode] Streaming Resource: Reached Decision id=27408 codes=(General=2000,Neither direct play nor conversion is available. Direct Play=3000,App cannot direct play this item. Direct play is disabled. Transcode=2003,File is unplayable. Color space is not supported.) media=(id=64917 part=(id=64946 decision=none container=mpegts protocol=hls streams=(Video=(id=166088 decision=transcode bitrate=2147483647 encoder=libx264 width=3840 height=2160) Audio=(id=166087 decision=copy channels=6 rate=48000))))
Aug 09, 2022 20:43:24.608 [0x7f8a8126fb38] DEBUG - Completed: [10.0.0.36:46866] 200 GET /video/:/transcode/universal/decision?directPlay=0&directStream=0&directStreamAudio=1&protocol=hls&fastSeek=1&path=%2Flibrary%2Fmetadata%2F27408&session=dcuewllzllwka9k9v5dbijcf&mediaIndex=0&partIndex=0&mediaBufferSize=50000&hasMDE=1&subtitleSize=100&videoQuality=100&videoResolution=3840x2160&audioBoost=100&location=lan (9 live) GZIP 8ms 783 bytes (pipelined: 7)
Aug 09, 2022 20:43:25.286 [0x7f8a81292b38] DEBUG - Completed: [10.0.0.36:46836] 200 GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cplayqueues&timeout=1 (9 live) GZIP 20001ms 5 bytes (pipelined: 3)
Aug 09, 2022 20:43:25.321 [0x7f8a7ff1bb38] DEBUG - Request: [10.0.0.36:46836 (Subnet)] GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cplayqueues&timeout=1 (9 live) #91a GZIP Signed-in Token (TuncTaylan) (LG OLED65C7D-Z)
Aug 09, 2022 20:43:25.321 [0x7f8a7ff1bb38] DEBUG - Content-Length is -1 (of total: -1).
Aug 09, 2022 20:43:27.855 [0x7f8a8004bb38] DEBUG - Request: [10.0.0.36:46866 (Subnet)] POST /log (9 live) #919 GZIP Signed-in Token (TuncTaylan) (LG OLED65C7D-Z)
Aug 09, 2022 20:43:27.855 [0x7f8a8004bb38] INFO - [Req#919] [Plex for LG] [TuncTaylan:jo35gny9rltyb9sh25uwaed4] Navigating to screen: VisualMediaPlaybackScreen
Aug 09, 2022 20:43:27.855 [0x7f8a8004bb38] WARN - [Req#919] [Plex for LG] [TuncTaylan:jo35gny9rltyb9sh25uwaed4] themeChanged is not defined for @autoCallback property: themeOverride
Aug 09, 2022 20:43:27.855 [0x7f8a8004bb38] INFO - [Req#919] [Plex for LG] [TuncTaylan:jo35gny9rltyb9sh25uwaed4] Navigated to screen: VisualMediaPlaybackScreen
Aug 09, 2022 20:43:27.855 [0x7f8a8004bb38] INFO - [Req#919] [Plex for LG] [TuncTaylan:jo35gny9rltyb9sh25uwaed4] [PlaybackMetrics] Attaching playback metrics to PlayerController
Aug 09, 2022 20:43:27.855 [0x7f8a8004bb38] INFO - [Req#919] [Plex for LG] [TuncTaylan:jo35gny9rltyb9sh25uwaed4] [SubtitleConnectionManager] Subtitle connection ignored. App is not rendering subtitles.
Aug 09, 2022 20:43:27.855 [0x7f8a8004bb38] INFO - [Req#919] [Plex for LG] [TuncTaylan:jo35gny9rltyb9sh25uwaed4] [ServerConnectionTestManager] Stopped
Aug 09, 2022 20:43:27.855 [0x7f8a8004bb38] INFO - [Req#919] [Plex for LG] [TuncTaylan:jo35gny9rltyb9sh25uwaed4] [MDE] Application decision, directPlay: false, directStreamVideo: false, directStreamAudio: true
Aug 09, 2022 20:43:27.855 [0x7f8a8004bb38] INFO - [Req#919] [Plex for LG] [TuncTaylan:jo35gny9rltyb9sh25uwaed4]     Cannot direct play with protocol: http, codec: hevc. Reason: Dolby Vision Profile 5 is not supported
Aug 09, 2022 20:43:27.855 [0x7f8a8004bb38] INFO - [Req#919] [Plex for LG] [TuncTaylan:jo35gny9rltyb9sh25uwaed4]     Cannot direct stream with protocol: hls, codec: hevc. Reason: Dolby Vision Profile 5 is not supported
Aug 09, 2022 20:43:27.855 [0x7f8a8004bb38] INFO - [Req#919] [Plex for LG] [TuncTaylan:jo35gny9rltyb9sh25uwaed4]   videoStream: {
  "id": 166088,
  "streamType": 1,
  "default": true,
  "codec": "hevc",
  "index": 1,
  "bitrate": 16476,
  "DOVILevel": 6,
  "DOVIProfile": 5,
  "bitDepth": 10,
  "codecID": "dvhe",
  "codedWidth": 3840,
  "colorRange": "pc",
  "frameRate": 24,
  "height": 2160,
  "level": 150,
  "refFrames": 1,
  "width": 3840,
Aug 09, 2022 20:43:27.855 [0x7f8a8004bb38] INFO - [Req#919] [Plex for LG] [TuncTaylan:jo35gny9rltyb9sh25uwaed4]   audioStream: {
  "id": 166087,
  "streamType": 2,
  "selected": true,
  "default": true,
  "codec": "eac3",
  "index": 0,
  "channels": 6,
  "bitrate": 768,
  "language": "English",
  "displayTitle": "English (EAC3 5.1)",
  "extendedDisplayTitle": "English (EAC3 5.1)"
Aug 09, 2022 20:43:27.855 [0x7f8a8004bb38] INFO - [Req#919] [Plex for LG] [TuncTaylan:jo35gny9rltyb9sh25uwaed4]   subtitleStream: none
Aug 09, 2022 20:43:27.855 [0x7f8a8004bb38] WARN - [Req#919] [Plex for LG] [TuncTaylan:jo35gny9rltyb9sh25uwaed4] Failed to create and set current playable media item - File is unplayable. Color space is not supported.
Aug 09, 2022 20:43:27.855 [0x7f8a8004bb38] WARN - [Req#919] [Plex for LG] [TuncTaylan:jo35gny9rltyb9sh25uwaed4] [PlaybackSessionController] we failed to create a playable URL!
Aug 09, 2022 20:43:27.855 [0x7f8a8004bb38] ERROR - [Req#919] [Plex for LG] [TuncTaylan:jo35gny9rltyb9sh25uwaed4] Playback error occurred. Reason: FailedToCreatePlayable, Failed to create a playable with the current play queue item! Message: File is unplayable. Color space is not supported.
Aug 09, 2022 20:43:27.855 [0x7f8a8004bb38] WARN - [Req#919] [Plex for LG] [TuncTaylan:jo35gny9rltyb9sh25uwaed4] [PlaybackSessionController] could not retry, reporting error
Aug 09, 2022 20:43:27.855 [0x7f8a8004bb38] WARN - [Req#919] [Plex for LG] [TuncTaylan:jo35gny9rltyb9sh25uwaed4] [PlaybackMetrics] Player sent ready signal or closed but no player or playable provided!
Aug 09, 2022 20:43:27.855 [0x7f8a8004bb38] INFO - [Req#919] [Plex for LG] [TuncTaylan:jo35gny9rltyb9sh25uwaed4] Opening modal: ActionsModal
Aug 09, 2022 20:43:27.855 [0x7f8a8004bb38] INFO - [Req#919] [Plex for LG] [TuncTaylan:jo35gny9rltyb9sh25uwaed4] Opened modal: ActionsModal
Aug 09, 2022 20:43:27.855 [0x7f8a81292b38] DEBUG - Completed: [10.0.0.36:46866] 200 POST /log (9 live) GZIP 0ms 320 bytes (pipelined: 8)
and from the other movie:
Aug 09, 2022 20:45:05.678 [0x7f8a7fe78b38] DEBUG - Content-Length is -1 (of total: -1).
Aug 09, 2022 20:45:05.847 [0x7f8a7ff1bb38] DEBUG - Request: [10.0.0.36:46914 (Subnet)] GET /photo/:/transcode?width=240&height=240&url=https%3A%2F%2Fmetadata-static.plex.tv%2F9%2Fpeople%2F9b82083b24e313ce425b37fd23f368b1.jpg&minSize=1&upscale=1 (9 live) #95b GZIP Signed-in Token (TuncTaylan) (LG OLED65C7D-Z)
Aug 09, 2022 20:45:05.847 [0x7f8a80557b38] DEBUG - Request: [10.0.0.36:46932 (Subnet)] GET /photo/:/transcode?width=240&height=240&url=https%3A%2F%2Fmetadata-static.plex.tv%2Fpeople%2F5d77685285719b001f3a8b47.jpg&minSize=1&upscale=1 (9 live) #959 GZIP Signed-in Token (TuncTaylan) (LG OLED65C7D-Z)
Aug 09, 2022 20:45:05.847 [0x7f8a8004bb38] DEBUG - Request: [10.0.0.36:46916 (Subnet)] GET /photo/:/transcode?width=240&height=240&url=https%3A%2F%2Fmetadata-static.plex.tv%2F2%2Fpeople%2F202a4c448f7e2aeb7424ff3438ac1d44.jpg&minSize=1&upscale=1 (9 live) #958 GZIP Signed-in Token (TuncTaylan) (LG OLED65C7D-Z)
Aug 09, 2022 20:45:05.848 [0x7f8a7fe78b38] DEBUG - Request: [10.0.0.36:46900 (Subnet)] GET /photo/:/transcode?width=240&height=240&url=https%3A%2F%2Fmetadata-static.plex.tv%2F0%2Fpeople%2F00320b963750c4dcd84a9cf3a352cc21.jpg&minSize=1&upscale=1 (9 live) #96b GZIP Signed-in Token (TuncTaylan) (LG OLED65C7D-Z)
Aug 09, 2022 20:45:05.848 [0x7f8a7ff57b38] DEBUG - Request: [10.0.0.36:46918 (Subnet)] GET /photo/:/transcode?width=240&height=240&url=https%3A%2F%2Fmetadata-static.plex.tv%2Ff%2Fpeople%2Fff98309ef431d3a4bfc8ac4136bfb68c.jpg&minSize=1&upscale=1 (9 live) #957 GZIP Signed-in Token (TuncTaylan) (LG OLED65C7D-Z)
Aug 09, 2022 20:45:05.848 [0x7f8a80557b38] DEBUG - [Req#959] Photo transcoder: Request for url [https://metadata-static.plex.tv/people/5d77685285719b001f3a8b47.jpg] (is local: 0 upscaled: 1)
Aug 09, 2022 20:45:05.848 [0x7f8a80557b38] DEBUG - Content-Length of /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache/PhotoTranscoder/2a/2a31a29a47e19480e154e0685b62bb845e074d39.jpg is 8050 (of total: 8050).
Aug 09, 2022 20:45:05.848 [0x7f8a7ff1bb38] DEBUG - [Req#95b] Photo transcoder: Request for url [https://metadata-static.plex.tv/9/people/9b82083b24e313ce425b37fd23f368b1.jpg] (is local: 0 upscaled: 1)
Aug 09, 2022 20:45:05.848 [0x7f8a7ff1bb38] DEBUG - Content-Length of /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache/PhotoTranscoder/3a/3aba61fcb7c72f7ec68e86cf43eba33cfb5923bc.jpg is 6171 (of total: 6171).
Aug 09, 2022 20:45:05.848 [0x7f8a81292b38] DEBUG - Completed: [10.0.0.36:46932] 200 GET /photo/:/transcode?width=240&height=240&url=https%3A%2F%2Fmetadata-static.plex.tv%2Fpeople%2F5d77685285719b001f3a8b47.jpg&minSize=1&upscale=1 (9 live) GZIP 0ms 8050 bytes (pipelined: 3)
Aug 09, 2022 20:45:05.848 [0x7f8a8126fb38] DEBUG - Completed: [10.0.0.36:46914] 200 GET /photo/:/transcode?width=240&height=240&url=https%3A%2F%2Fmetadata-static.plex.tv%2F9%2Fpeople%2F9b82083b24e313ce425b37fd23f368b1.jpg&minSize=1&upscale=1 (9 live) GZIP 1ms 6171 bytes (pipelined: 6)
Aug 09, 2022 20:45:05.849 [0x7f8a8004bb38] DEBUG - [Req#958] Photo transcoder: Request for url [https://metadata-static.plex.tv/2/people/202a4c448f7e2aeb7424ff3438ac1d44.jpg] (is local: 0 upscaled: 1)
Aug 09, 2022 20:45:05.849 [0x7f8a7fe78b38] DEBUG - [Req#96b] Photo transcoder: Request for url [https://metadata-static.plex.tv/0/people/00320b963750c4dcd84a9cf3a352cc21.jpg] (is local: 0 upscaled: 1)
Aug 09, 2022 20:45:05.849 [0x7f8a7fe78b38] DEBUG - Content-Length of /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache/PhotoTranscoder/43/438ff82aed407e8060a861c387275380d07ea1d0.jpg is 9019 (of total: 9019).
Aug 09, 2022 20:45:05.849 [0x7f8a8004bb38] DEBUG - Content-Length of /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache/PhotoTranscoder/c9/c9fe0d52a62610171c281e76f7916f3b0d0963c4.jpg is 8773 (of total: 8773).
Aug 09, 2022 20:45:05.849 [0x7f8a7ff57b38] DEBUG - [Req#957] Photo transcoder: Request for url [https://metadata-static.plex.tv/f/people/ff98309ef431d3a4bfc8ac4136bfb68c.jpg] (is local: 0 upscaled: 1)
Aug 09, 2022 20:45:05.849 [0x7f8a81292b38] DEBUG - Completed: [10.0.0.36:46900] 200 GET /photo/:/transcode?width=240&height=240&url=https%3A%2F%2Fmetadata-static.plex.tv%2F0%2Fpeople%2F00320b963750c4dcd84a9cf3a352cc21.jpg&minSize=1&upscale=1 (9 live) GZIP 1ms 9019 bytes (pipelined: 17)
Aug 09, 2022 20:45:05.849 [0x7f8a81292b38] DEBUG - Completed: [10.0.0.36:46916] 200 GET /photo/:/transcode?width=240&height=240&url=https%3A%2F%2Fmetadata-static.plex.tv%2F2%2Fpeople%2F202a4c448f7e2aeb7424ff3438ac1d44.jpg&minSize=1&upscale=1 (9 live) GZIP 1ms 8773 bytes (pipelined: 6)
Aug 09, 2022 20:45:05.849 [0x7f8a7ff57b38] DEBUG - Content-Length of /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache/PhotoTranscoder/76/76d4a7f0b93b37e43c8d4ca574f82fbc34ddcbf4.jpg is 8141 (of total: 8141).
Aug 09, 2022 20:45:05.850 [0x7f8a81292b38] DEBUG - Completed: [10.0.0.36:46918] 200 GET /photo/:/transcode?width=240&height=240&url=https%3A%2F%2Fmetadata-static.plex.tv%2Ff%2Fpeople%2Fff98309ef431d3a4bfc8ac4136bfb68c.jpg&minSize=1&upscale=1 (9 live) GZIP 2ms 8141 bytes (pipelined: 8)
Aug 09, 2022 20:45:07.422 [0x7f8a7ff1bb38] DEBUG - Request: [10.0.0.36:46918 (Subnet)] POST /log (9 live) #971 GZIP Signed-in Token (TuncTaylan) (LG OLED65C7D-Z)
Aug 09, 2022 20:45:07.422 [0x7f8a7ff1bb38] INFO - [Req#971] [Plex for LG] [TuncTaylan:jo35gny9rltyb9sh25uwaed4] Navigating to screen: PreplayScreen
Aug 09, 2022 20:45:07.422 [0x7f8a7ff1bb38] INFO - [Req#971] [Plex for LG] [TuncTaylan:jo35gny9rltyb9sh25uwaed4] Navigated to screen: PreplayScreen
Aug 09, 2022 20:45:07.422 [0x7f8a8126fb38] DEBUG - Completed: [10.0.0.36:46918] 200 POST /log (9 live) GZIP 0ms 320 bytes (pipelined: 9)
Aug 09, 2022 20:45:14.062 [0x7f8a7ff1bb38] DEBUG - Request: [10.0.0.36:46918 (Subnet)] POST /playQueues?own=1&excludeElements=Actor%2CCollection%2CCountry%2CDirector%2CGenre%2CLabel%2CMood%2CPart%2CProducer%2CRole%2CSimilar%2CWriter%2CPhoto&excludeFields=file%2Ctagline&uri=server%3A%2F%2Ff29069d1ce4a9c2e401c3e13122d03586d9523cc%2Fcom.plexapp.plugins.library%2Flibrary%2Fmetadata%2F24289&type=video&continuous=0&includeRelated=0&shuffle=0&repeat=0&extrasPrefixCount=0 (9 live) #972 GZIP Signed-in Token (TuncTaylan) (LG OLED65C7D-Z)
Aug 09, 2022 20:45:14.062 [0x7f8a7ff1bb38] DEBUG - [Req#972] PlayQueue: Converted 'server://f29069d1ce4a9c2e401c3e13122d03586d9523cc/com.plexapp.plugins.library/library/metadata/24289' to 'library://x/item/%2Flibrary%2Fmetadata%2F24289'
Aug 09, 2022 20:45:14.062 [0x7f8a7ff1bb38] DEBUG - [Req#972] PlayQueue: 0 generated IDs compressed down to a 20 byte blob.
Aug 09, 2022 20:45:14.069 [0x7f8a7ff1bb38] DEBUG - [Req#972] PlayQueue: Start index: 0 End index: 0 Count: 1
Aug 09, 2022 20:45:14.069 [0x7f8a7ff1bb38] DEBUG - [Req#972] PlayQueue: 1 generated IDs compressed down to a 24 byte blob.
Aug 09, 2022 20:45:14.069 [0x7f8a7ff1bb38] DEBUG - [Req#972] PlayQueue: Added 1 items in 0.0 sec.
Aug 09, 2022 20:45:14.095 [0x7f8a7ff1bb38] DEBUG - [Req#972] Extras: Looking for extras for item plex://movie/5e833ef0ec007c00413115b6 with unwatched: 0 fromLibrary: 1 fromTheater: 0 fromBluray: 0 and preroll count: 0.
Aug 09, 2022 20:45:14.095 [0x7f8a7ff1bb38] DEBUG - [Req#972] Extras: Using allowable content ratings: , NC-17, NR, PG-13, R.
Aug 09, 2022 20:45:14.095 [0x7f8a7ff1bb38] DEBUG - [Req#972] Extras: Using genres: Science Fiction, Action.
Aug 09, 2022 20:45:14.096 [0x7f8a7ff1bb38] DEBUG - [Req#972] Extras: Found 0 extras from library.
Aug 09, 2022 20:45:14.099 [0x7f8a81292b38] DEBUG - Completed: [10.0.0.36:46918] 200 POST /playQueues?own=1&excludeElements=Actor%2CCollection%2CCountry%2CDirector%2CGenre%2CLabel%2CMood%2CPart%2CProducer%2CRole%2CSimilar%2CWriter%2CPhoto&excludeFields=file%2Ctagline&uri=server%3A%2F%2Ff29069d1ce4a9c2e401c3e13122d03586d9523cc%2Fcom.plexapp.plugins.library%2Flibrary%2Fmetadata%2F24289&type=video&continuous=0&includeRelated=0&shuffle=0&repeat=0&extrasPrefixCount=0 (9 live) GZIP 37ms 1461 bytes (pipelined: 10)
Aug 09, 2022 20:45:14.472 [0x7f8a8004bb38] DEBUG - Request: [10.0.0.36:46918 (Subnet)] GET /library/metadata/24289?checkFiles=1&includeChapters=1&includeMarkers=1 (9 live) #975 GZIP Signed-in Token (TuncTaylan) (LG OLED65C7D-Z)
Aug 09, 2022 20:45:14.476 [0x7f8a8004bb38] DEBUG - [Req#975] We're going to try to auto-select an audio stream for account 1.
Aug 09, 2022 20:45:14.476 [0x7f8a8004bb38] DEBUG - [Req#975] Selecting best audio stream for part ID 52805 (autoselect: 1 language: en)
Aug 09, 2022 20:45:14.476 [0x7f8a8004bb38] DEBUG - [Req#975] Audio Stream: 130511, Subtitle Stream: 130584
Aug 09, 2022 20:45:14.477 [0x7f8a8126fb38] DEBUG - Completed: [10.0.0.36:46918] 200 GET /library/metadata/24289?checkFiles=1&includeChapters=1&includeMarkers=1 (9 live) GZIP 5ms 5492 bytes (pipelined: 11)
Aug 09, 2022 20:45:14.954 [0x7f8a7ff1bb38] DEBUG - Request: [10.0.0.36:46918 (Subnet)] GET /video/:/transcode/universal/decision?directPlay=0&directStream=0&directStreamAudio=1&protocol=hls&fastSeek=1&path=%2Flibrary%2Fmetadata%2F24289&session=3ctd1ble9pxbhuxrimcdsaxa&mediaIndex=0&partIndex=0&mediaBufferSize=50000&hasMDE=1&subtitleSize=100&videoQuality=100&videoResolution=3840x2160&audioBoost=100&subtitles=burn&location=lan (9 live) #976 GZIP Signed-in Token (TuncTaylan) (LG OLED65C7D-Z)
Aug 09, 2022 20:45:14.954 [0x7f8a7ff1bb38] DEBUG - [Req#976/Transcode] Found session GUID of 3ctd1ble9pxbhuxrimcdsaxa in session start.
Aug 09, 2022 20:45:14.954 [0x7f8a7ff1bb38] DEBUG - [Req#976/Transcode] TranscodeUniversalRequest: adapting profile with augmentation data: add-transcode-target(type=videoProfile&context=streaming&protocol=hls&container=mpegts&videoCodec=h264,hevc,mpeg2video,mpeg4&audioCodec=aac,ac3,eac3,mp2,mp3)+add-limitation(scope=videoAudioCodec&scopeName=mp2&type=upperBound&name=audio.bitrate&value=350)+add-limitation(scope=videoAudioCodec&scopeName=mp3&type=upperBound&name=audio.bitrate&value=350)+add-limitation(scope=videoCodec&scopeName=h264&type=upperBound&name=video.level&value=51)+add-limitation(scope=videoTranscodeTarget&scopeName=h264&scopeType=videoCodec&context=streaming&protocol=hls&type=upperBound&name=video.bitDepth&value=8)+add-limitation(scope=videoTranscodeTarget&scopeName=h264&scopeType=videoCodec&context=streaming&protocol=hls&type=upperBound&name=video.width&value=3840)+add-limitation(scope=videoTranscodeTarget&scopeName=h264&scopeType=videoCodec&context=streaming&protocol=hls&type=upperBound&name=video.height&value=2160)+add-limitation(scope=videoTranscodeTarget&scopeName=hevc&scopeType=videoCodec&context=streaming&protocol=hls&type=upperBound&name=video.bitDepth&value=10)+add-limitation(scope=videoTranscodeTarget&scopeName=hevc&scopeType=videoCodec&context=streaming&protocol=hls&type=upperBound&name=video.width&value=3840)+add-limitation(scope=videoTranscodeTarget&scopeName=hevc&scopeType=videoCodec&context=streaming&protocol=hls&type=upperBound&name=video.height&value=2160)+add-limitation(scope=videoCodec&scopeName=hevc&type=notMatch&name=video.DOVIProfile&value=5)+add-limitation(scope=videoTranscodeTarget&scopeName=mpeg2video&scopeType=videoCodec&context=streaming&protocol=hls&type=upperBound&name=video.bitDepth&value=8)+add-limitation(scope=videoTranscodeTarget&scopeName=mpeg2video&scopeType=videoCodec&context=streaming&protocol=hls&type=upperBound&name=video.width&value=1920)+add-limitation(scope=videoTranscodeTarget&scopeName=mpeg2video&scopeType=videoCodec&context=streaming&protocol=hls&type=upperBound&name=video.height&value=1080)+add-limitation(scope=videoTranscodeTarget&scopeName=mpeg4&scopeType=videoCodec&context=streaming&protocol=hls&type=upperBound&name=video.bitDepth&value=8)+add-limitation(scope=videoTranscodeTarget&scopeName=mpeg4&scopeType=videoCodec&context=streaming&protocol=hls&type=upperBound&name=video.width&value=1920)+add-limitation(scope=videoTranscodeTarget&scopeName=mpeg4&scopeType=videoCodec&context=streaming&protocol=hls&type=upperBound&name=video.height&value=1080)+add-transcode-target(type=subtitleProfile&protocol=http&context=all&subtitleCodec=srt&container=srt)
Aug 09, 2022 20:45:14.955 [0x7f8a7ff1bb38] DEBUG - [Req#976/Transcode] TranscodeUniversalRequest: using augmented profile Generic
Aug 09, 2022 20:45:14.955 [0x7f8a7ff1bb38] DEBUG - [Req#976/Transcode] Downloading document http://127.0.0.1:32400/library/metadata/24289?includeBandwidths=1&offset=-1&X-Plex-Incomplete-Segments=1&X-Plex-Session-Identifier=jo35gny9rltyb9sh25uwaed4
Aug 09, 2022 20:45:14.959 [0x7f8a7ff1bb38] DEBUG - [Req#976/Transcode/Req#977] We're going to try to auto-select an audio stream for account 1.
Aug 09, 2022 20:45:14.959 [0x7f8a7ff1bb38] DEBUG - [Req#976/Transcode/Req#977] Selecting best audio stream for part ID 52805 (autoselect: 1 language: en)
Aug 09, 2022 20:45:14.959 [0x7f8a7ff1bb38] DEBUG - [Req#976/Transcode/Req#977] Audio Stream: 130511, Subtitle Stream: 130584
Aug 09, 2022 20:45:14.960 [0x7f8a7ff1bb38] DEBUG - [Req#976/Transcode] MDE: Selected protocol hls; container: mpegts
Aug 09, 2022 20:45:14.960 [0x7f8a7ff1bb38] DEBUG - [Req#976/Transcode] MDE: analyzing media item 52777
Aug 09, 2022 20:45:14.960 [0x7f8a7ff1bb38] DEBUG - [Req#976/Transcode] MDE: The Matrix Resurrections (2021): Direct Play is disabled
Aug 09, 2022 20:45:14.960 [0x7f8a7ff1bb38] DEBUG - [Req#976/Transcode] MDE: The Matrix Resurrections (2021): media must be transcoded in order to use the hls protocol
Aug 09, 2022 20:45:14.960 [0x7f8a7ff1bb38] DEBUG - [Req#976/Transcode] MDE: The Matrix Resurrections (2021): selected subtitle cannot be converted to a compatible format, burning into video stream
Aug 09, 2022 20:45:14.960 [0x7f8a7ff1bb38] DEBUG - [Req#976/Transcode] MDE: The Matrix Resurrections (2021): Direct Streaming is disabled, so video stream will be transcoded
Aug 09, 2022 20:45:14.960 [0x7f8a7ff1bb38] DEBUG - [Req#976/Transcode] MDE: The Matrix Resurrections (2021): no remuxable profile found, so video stream will be transcoded
Aug 09, 2022 20:45:14.960 [0x7f8a7ff1bb38] DEBUG - [Req#976/Transcode] MDE: Cannot direct stream video stream due to profile or setting limitations
Aug 09, 2022 20:45:14.960 [0x7f8a7ff1bb38] DEBUG - [Req#976/Transcode] MDE: The Matrix Resurrections (2021): selected media 0 / 52777
Aug 09, 2022 20:45:14.960 [0x7f8a7ff1bb38] ERROR - [Req#976/Transcode] Streaming Resource: Cannot make a decision because either the file is unplayable or the client provided bad data
Aug 09, 2022 20:45:14.960 [0x7f8a7ff1bb38] DEBUG - [Req#976/Transcode] Streaming Resource: Reached Decision id=24289 codes=(General=2000,Neither direct play nor conversion is available. Direct Play=3000,App cannot direct play this item. Direct play is disabled. Transcode=2003,File is unplayable. Color space is not supported.) media=(id=52777 part=(id=52805 decision=none container=mpegts protocol=hls streams=(Video=(id=130510 decision=transcode bitrate=2147483647 encoder=libx264 width=3840 height=2160) Audio=(id=130511 decision=copy channels=6 rate=48000) Subtitle=(id=130584 decision=burn languageCode=tur location=embedded))))
Aug 09, 2022 20:45:14.960 [0x7f8a81292b38] DEBUG - Completed: [10.0.0.36:46918] 200 GET /video/:/transcode/universal/decision?directPlay=0&directStream=0&directStreamAudio=1&protocol=hls&fastSeek=1&path=%2Flibrary%2Fmetadata%2F24289&session=3ctd1ble9pxbhuxrimcdsaxa&mediaIndex=0&partIndex=0&mediaBufferSize=50000&hasMDE=1&subtitleSize=100&videoQuality=100&videoResolution=3840x2160&audioBoost=100&subtitles=burn&location=lan (9 live) GZIP 6ms 783 bytes (pipelined: 12)
Aug 09, 2022 20:45:18.482 [0x7f8a7ff1bb38] DEBUG - Request: [10.0.0.36:46918 (Subnet)] POST /log (9 live) #979 GZIP Signed-in Token (TuncTaylan) (LG OLED65C7D-Z)
Aug 09, 2022 20:45:18.482 [0x7f8a7ff1bb38] INFO - [Req#979] [Plex for LG] [TuncTaylan:jo35gny9rltyb9sh25uwaed4] Navigating to screen: VisualMediaPlaybackScreen
Aug 09, 2022 20:45:18.482 [0x7f8a7ff1bb38] WARN - [Req#979] [Plex for LG] [TuncTaylan:jo35gny9rltyb9sh25uwaed4] themeChanged is not defined for @autoCallback property: themeOverride
Aug 09, 2022 20:45:18.482 [0x7f8a7ff1bb38] INFO - [Req#979] [Plex for LG] [TuncTaylan:jo35gny9rltyb9sh25uwaed4] Navigated to screen: VisualMediaPlaybackScreen
Aug 09, 2022 20:45:18.482 [0x7f8a7ff1bb38] INFO - [Req#979] [Plex for LG] [TuncTaylan:jo35gny9rltyb9sh25uwaed4] [PlaybackMetrics] Attaching playback metrics to PlayerController
Aug 09, 2022 20:45:18.482 [0x7f8a7ff1bb38] INFO - [Req#979] [Plex for LG] [TuncTaylan:jo35gny9rltyb9sh25uwaed4] [SubtitleConnectionManager] Subtitle connection ignored. App is not rendering subtitles.
Aug 09, 2022 20:45:18.482 [0x7f8a7ff1bb38] INFO - [Req#979] [Plex for LG] [TuncTaylan:jo35gny9rltyb9sh25uwaed4] [ServerConnectionTestManager] Stopped
Aug 09, 2022 20:45:18.482 [0x7f8a7ff1bb38] WARN - [Req#979] [Plex for LG] [TuncTaylan:jo35gny9rltyb9sh25uwaed4] _onOnPlayPauseInvokedChanged is not defined for @autoCallback property: onPlayPauseInvoked
Aug 09, 2022 20:45:18.482 [0x7f8a7ff1bb38] INFO - [Req#979] [Plex for LG] [TuncTaylan:jo35gny9rltyb9sh25uwaed4] [MDE] Application decision, directPlay: false, directStreamVideo: false, directStreamAudio: true
Aug 09, 2022 20:45:18.482 [0x7f8a7ff1bb38] INFO - [Req#979] [Plex for LG] [TuncTaylan:jo35gny9rltyb9sh25uwaed4]     Cannot direct play with protocol: http, codec: hevc. Reason: Dolby Vision Profile 5 is not supported
Aug 09, 2022 20:45:18.482 [0x7f8a7ff1bb38] INFO - [Req#979] [Plex for LG] [TuncTaylan:jo35gny9rltyb9sh25uwaed4]     Cannot direct stream with protocol: hls, codec: hevc. Reason: Dolby Vision Profile 5 is not supported
Aug 09, 2022 20:45:18.482 [0x7f8a7ff1bb38] INFO - [Req#979] [Plex for LG] [TuncTaylan:jo35gny9rltyb9sh25uwaed4]   videoStream: {
  "id": 130510,
  "streamType": 1,
  "default": true,
  "codec": "hevc",
  "index": 0,
  "bitrate": 17805,
  "DOVILevel": 6,
  "DOVIProfile": 5,
  "bitDepth": 10,
  "codecID": "dvhe",
  "codedWidth": 3840,
  "colorRange": "pc",
  "frameRate": 23.976,
  "height": 2160,
  "level": 150,
  "refFrames": 1,
  "width": 3840,
Aug 09, 2022 20:45:18.482 [0x7f8a7ff1bb38] INFO - [Req#979] [Plex for LG] [TuncTaylan:jo35gny9rltyb9sh25uwaed4]   audioStream: {
  "id": 130511,
  "streamType": 2,
  "selected": true,
  "default": true,
  "codec": "eac3",
  "index": 1,
  "channels": 6,
  "bitrate": 768,
Aug 09, 2022 20:45:18.482 [0x7f8a7ff1bb38] INFO - [Req#979] [Plex for LG] [TuncTaylan:jo35gny9rltyb9sh25uwaed4]   subtitleStream: {
  "id": 130584,
  "key": "/library/streams/130584",
  "streamType": 3,
  "selected": true,
  "codec": "srt",
  "language": "Turkish",
  "languageTag": "tur",
  "format": "srt",
  "providerTitle": "OpenSubtitles",
  "score": "69",
  "sourceKey": "/library/streams/1957489379?provider=OpenSubtitles&url=https%3A%2F%2Fdl.opensubtitles.org%2Fen%2Fdownload%2Fsrc-api%2Fvrf-19fb0c67%2Ffilead%2F1957489379.gz&enc=UTF-8",
  "title": "The.Matrix.Resurrections.2021.1080p.HMAX.WEB-DL.DDP5.1.Atmos.x264-MZABI",
  "transient": "1",
  "userID": "1",
  "displayTitle": "Turkish (SRT OpenSubtitles)",
  "extendedDisplayTitle": "The.Matrix.Resurrections.2021.1080p.HMAX.WEB-DL.DDP5.1.Atmos.x264-MZABI (Turkish SRT OpenSubtitles)"
Aug 09, 2022 20:45:18.482 [0x7f8a7ff1bb38] INFO - [Req#979] [Plex for LG] [TuncTaylan:jo35gny9rltyb9sh25uwaed4] Forcing subtitle burn: HLS direct stream incompatible
Aug 09, 2022 20:45:18.482 [0x7f8a7ff1bb38] INFO - [Req#979] [Plex for LG] [TuncTaylan:jo35gny9rltyb9sh25uwaed4] Cannot direct play subtitles. Reason: Server required to burn subtitles
Aug 09, 2022 20:45:18.482 [0x7f8a7ff1bb38] WARN - [Req#979] [Plex for LG] [TuncTaylan:jo35gny9rltyb9sh25uwaed4] Failed to create and set current playable media item - File is unplayable. Color space is not supported.
Aug 09, 2022 20:45:18.482 [0x7f8a7ff1bb38] WARN - [Req#979] [Plex for LG] [TuncTaylan:jo35gny9rltyb9sh25uwaed4] [PlaybackSessionController] we failed to create a playable URL!
Aug 09, 2022 20:45:18.482 [0x7f8a7ff1bb38] ERROR - [Req#979] [Plex for LG] [TuncTaylan:jo35gny9rltyb9sh25uwaed4] Playback error occurred. Reason: FailedToCreatePlayable, Failed to create a playable with the current play queue item! Message: File is unplayable. Color space is not supported.
Aug 09, 2022 20:45:18.482 [0x7f8a7ff1bb38] WARN - [Req#979] [Plex for LG] [TuncTaylan:jo35gny9rltyb9sh25uwaed4] [PlaybackSessionController] could not retry, reporting error
Aug 09, 2022 20:45:18.482 [0x7f8a7ff1bb38] WARN - [Req#979] [Plex for LG] [TuncTaylan:jo35gny9rltyb9sh25uwaed4] [PlaybackMetrics] Player sent ready signal or closed but no player or playable provided!
Aug 09, 2022 20:45:18.482 [0x7f8a7ff1bb38] INFO - [Req#979] [Plex for LG] [TuncTaylan:jo35gny9rltyb9sh25uwaed4] Opening modal: ActionsModal
Aug 09, 2022 20:45:18.482 [0x7f8a7ff1bb38] INFO - [Req#979] [Plex for LG] [TuncTaylan:jo35gny9rltyb9sh25uwaed4] Opened modal: ActionsModal
Aug 09, 2022 20:45:18.482 [0x7f8a8126fb38] DEBUG - Completed: [10.0.0.36:46918] 200 POST /log (9 live) GZIP 0ms 320 bytes (pipelined: 13)
And the full logs file:
Plex Media Server Logs_2022-08-09_20-45-56.zip (570.2 KB)
Huh? These look like server logs. How is this different from the first set?
Ehm, if I enable logging on the client, it logs the the same file (I think) “Plex Media Server.log”
The zipped file contains all the logs files in the log folder.
What do you need specifically?
Edit: the last one includes everything, so just check the last ones.
Right. The client logs to the server. I was just wondering what the difference between that log is compared to the earlier ones you sent. I haven’t looked at your logs yet. Did you not enable the setting in the earlier attempts so you were providing new files?
In the earlier attempts I forget to enable client logging. The last one includes the client logs (DEBUG).
Sorry…
Hi @anon18523487 , will you have a chance to check out this issue? Do you need any more information from me?
Ok, I found out that the app can detect if the TV supports DV profile 5 or not. When it doesn’t support it, then we will not play the file as this would playback with wrong colors. Other Plex clients will playback with the wrong colors. We are reviewing this decision to not playback the file.
Would you want the file to playback with the wrong colors?
But the TV supports it and it worked perfectly until the new detection is built in the app. Yes, at least give us a choice to force it, the colors were not wrong.
Edit: other Plex clients doesn’t play anymore also.
I’m not sure whether to reply here or the other thread which seems to be tackling the same issue. I’ll post here for now. My TV is the 4K LG OLED55B7T.
In case this info helps…
UP UNTIL A COUPLE OF WEEKS AGO:
I could play DV content via the Plex LG WebOS client most of the time as long as the file was an mp4. If it was an mkv, then IIRC the colors were wrong and the TV may not have displayed the ‘Dolby Vision’ banner when the playback began. But with mp4 DV files the tv indicated it was playing DV at the start of playback and the colours were perfectly correct! Occasionally I came across a DV mp4 file that would play correctly for 2–3mins before it would fall into an unwatchable stuttering playback state. I’m not sure what caused this, but most DV mp4 files did not have this issue and played perfectly. Oh and DV content played perfectly via Netflix.
IN THE LAST COUPLE OF WEEKS:
Now my DV mp4 files that previously worked perfectly via the Plex LG WebOS client come up with the ‘Playback Error. File is Unplayable. Color space is not supported.’ message and will not play at all. This seems like an error because up until recently they played fine and with correct colours. Oh and DV content is still playing perfectly via Netflix.
Hopefully this info helps with your testing and preparing a fix. I’m very anxious for the issue to be resolved. Much thanks for your attention to it.
hi,
i have an lg oled 65g6v, im in same boat the latest plex web os app update has stopped dv files from working, if i plug a firestick in same tv it then works, its 100% the app not server.
my mum has a c9 oled and plex works perfectly on her tv app.
all hdr10 works fine.
just need the fix on lg plex app.
thanks
Plex webOS v5.44.3 just posted:
  • Fixed Dolby Vision detection on some OLED models
I played the LG Amaze and LG Earth videos, both DV profile 5, on my B7 OLED.
TV displayed “Dolby Vision” when the video started. Colors correct.
Yes, I can confirm, that the version 5.44.3 fixed this issue. DV is working again. Thanks, @anon18523487
All fixed for me too with 5.44.3. Much thanks to the Plex team for addressing this!
