The commercial skip function on the DVR is not longer working, did that feature get removed? Note it is still an option on the advanced recording menu.
Working here PMS Version 1.19.3.2764 on nv SHIELD, recording stored on Synology NAS.
Also having this issue on PMS Version 1.19.3.2764 running on Synology DS918+. Hope it gets fixed soon.
(Crossposting to help others who are fighting this issue.)
So after a month or so of my commercial skip not working, I seem to have found a fix based on another thread. You go into the main DVR settings and disable the “Remove Commercials” option, save, then re-enable it. That seemed to magically kickstart mine. Hope it helps someone else.
