I am running on e Synology and I noticed that the Commercial Skip / remove feature will peg the CPU. Causing playback issues when watching anything. Also If you want to watch the recording while its recording or directly after you experience playback issues. Probably for the same reason.
Would it be possible to make the Commercial Skip removal work as a task. This way it can run over night causing less disruption? I love the feature but it is just taking up too many resources when running
