I just updated and I do not see anything to turn it off or on. But then I just saw something about FreeBSD support. I am running mine in a jail on FreeNAS. I have run into this issue before. Not all versions are created the same. When a release is announced the exceptions need to be added. I hate spending time looking for a feature that does not exist.
Documentation can be found here. It clearly states the following:
Is not currently available for FreeBSD installs.
You are correct but I should not need to look up every single feature to see if it is supported for my OS version.
They need to document it here with the release notes or create a matrix grid. Communication is the key to good customer service.
