Also missed the one i sent about a DVBSky T330 only seeing it as a DVB-T2 tuner and not DVB-T2/T/C so no cable scanning
@andrewpmoore@gmail.com,
You’re right, yours is not in there. I wanted to reach out and check with you first before publishing since your username contains your email address. Just wanted to make sure you’re ok with that as most everyone’s usernames are not email addresses. I don’t want to see your inbox flooded.
I’ll update with yours today.
Added DVBSky T330.
Yes dunno how that happened with my username, is there a way to change it? It was never intended to have the @gmail.com on it!
All you have to do is change your Plex username. Log in to Plex Web then hit this shortcut: https://app.plex.tv/desktop#!/account
Ping me when you’ve done that and I will add your tuner testing to the list with your new username.
Thanks, that’s my username sorted!
Excellent! I updated the tuners list with your addition.
I’ve tested the ATI TV wonder 600 usb and it does seem to work. My first test I had a station with poor signal and it didn’t work well, but after that it seemed normal when trying a stronger station. Recording, live tv etc. I added it to the google list too.
Just added another one to the list DVBSky T9580.
Thanks everyone. I’m going to go through and do a massive update today or tomorrow.
I just tested an ATI TV wonder PCI (not PCIe) and it didn’t work. Is that something I should even put in the list though? Is there any chance it’s just not looking for PCI devices at all?
EDIT: nope no need to put in the list, just remembered that thing had an analog tuner, no chance of working.
The link to the list doesn’t seem to work anymore, are SAT-IP tuners supported now?
We’ve updated the list to be a community-editable Google spreadsheet and expanded the unsupported tuners group to not require registration. More info here and the spreadsheet can be found here. We’ve also created this support article with more details. Its all linked in the announced thread in the community supported tuners forum section. SAT-IP is not officially supported at this time, though some have found certain modems and configurations to work. Your mileage will vary.
Sony PlayTV dual tuner worked perfectly for me - Ubuntu 16.04
Hi guys.
I’m looking to get my Digibit R1 integrated … I cannot activate SAT>IP functionality somewhere in the advanced options and it is not automatically discovered as well as not manually.
Seems all links for unsupported tuners and stuff do not work anymore.
As I cannot find information about SAT>IP anymore, can someone help out what the status is?
Or is there a hidden trick for SAT>IP hardware?
I have activated beta update channel and I’m plexPass user.
Thanks.
