Hi all, being granted access to community supported Tuners I’m now trying to Setup my Exip 414 with Plex DVR.
The Exip is listed as partially working and described as showing up immediately when initiating DVR Setup.
For me, however, the Setup is scanning endlessly with the tuner never showing up in the web ui.
Downloading the Plex Tuner Service log I see that the device is sucessfully detected…
PMS is running off my NAS: QNAP TS 459 Pro+, latest QTS 4.2
Plex Server Version 1.11.0.4666, Plex Client: Web App
Sat>IP Server: Kathrein Exip 414, Firmware: 0.5.12
Region: Germany
Other (software) Clients that successfully discover and stream from Exip:
- Elgato Eye TV
- DVBViewer Pro
- DVBViewer - Android App
The “web_service_t::process_device_discovery”, shown in the log below, repeats every few seconds
Jan 01, 2018 15:11:14.038 [0xf66b2b90] INFO - Plex Tuner Service v1.0.0.0 - unknown PC unknown - build: Jan 01, 2018 15:11:14.039 [0xf66b2b90] INFO - Linux version: 3.4.6 (#1 SMP Fri Dec 8 01:32:36 CST 2017), language: en-US Jan 01, 2018 15:11:14.040 [0xf66b2b90] INFO - Processor Intel(R) Atom(TM) CPU D525 @ 1.80GHz Jan 01, 2018 15:11:14.040 [0xf66b2b90] INFO - /share/MD0_DATA/.qpkg/PlexMediaServer/Plex Tuner Service /share/MD0_DATA/.qpkg/PlexMediaServer/Resources/Tuner/Private /share/MD0_DATA/.qpkg/PlexMediaServer/Resources/Tuner/Shared 1.11.0.4666-fc63598ba 32600 /waitmutex Jan 01, 2018 15:11:14.026 [0xf67e7700] INFO - * broker_t::start... Jan 01, 2018 15:11:14.395 [0xf67e7700] INFO - * device_manager_t::init. Jan 01, 2018 15:11:14.396 [0xf67e7700] INFO - * device_manager_t::init. Initialize provider manager Jan 01, 2018 15:11:14.396 [0xf67e7700] INFO - * device_manager_t::init. Initialize all device auxes Jan 01, 2018 15:11:14.396 [0xf67e7700] INFO - * dvb_device_factory_t::get_aux_list Jan 01, 2018 15:11:14.397 [0xf67e7700] INFO - * tvbutler_aux_t::init Jan 01, 2018 15:11:14.399 [0xf67e7700] INFO - * web_server_t::start. Starting web server on port 32600 Jan 01, 2018 15:13:01.692 [0xf5347b90] INFO - * web_service_t::process_device_discovery Jan 01, 2018 15:13:01.713 [0xf5347b90] INFO - * device_reactor_t::get_device_list () Jan 01, 2018 15:13:01.714 [0xf5347b90] INFO - * dvb_device_factory_t::get_device_list () Jan 01, 2018 15:13:03.798 [0xf5347b90] INFO - * SAT2IP - server discovered: 192.168.178.24 Jan 01, 2018 15:13:03.799 [0xf5347b90] INFO - * SAT2IP - description XML: http://192.168.178.24:80/rootDescr Jan 01, 2018 15:13:03.809 [0xf5347b90] INFO - * dvb_device_factory_t::get_device_list. Id dvb#sat2ip#0#uuid:7f764937-d0d7-11e1-9b23-00d0551c4981, Name KATHREIN Sat>IP Server (192.168.178.24) - 0, Standards 4 Jan 01, 2018 15:13:03.809 [0xf5347b90] INFO - * dvb_device_factory_t::get_device_list. Id dvb#sat2ip#1#uuid:7f764937-d0d7-11e1-9b23-00d0551c4981, Name KATHREIN Sat>IP Server (192.168.178.24) - 1, Standards 4 Jan 01, 2018 15:13:03.810 [0xf5347b90] INFO - * dvb_device_factory_t::get_device_list. Id dvb#sat2ip#2#uuid:7f764937-d0d7-11e1-9b23-00d0551c4981, Name KATHREIN Sat>IP Server (192.168.178.24) - 2, Standards 4 Jan 01, 2018 15:13:03.810 [0xf5347b90] INFO - * dvb_device_factory_t::get_device_list. Id dvb#sat2ip#3#uuid:7f764937-d0d7-11e1-9b23-00d0551c4981, Name KATHREIN Sat>IP Server (192.168.178.24) - 3, Standards 4 Jan 01, 2018 15:13:04.215 [0xf5347b90] INFO - * v4l::DeviceGetList_impl. getting v4l device list Jan 01, 2018 15:13:04.228 [0xf5347b90] INFO - * onetv_factory::DeviceGetListEx >> Jan 01, 2018 15:13:04.234 [0xf5347b90] INFO - * onetv_factory::DeviceGetListEx. Found device 7531:1 Jan 01, 2018 15:13:04.235 [0xf5347b90] INFO - * onetv_factory::DeviceGetListEx. Found device 7531:1 Jan 01, 2018 15:13:04.235 [0xf5347b90] INFO - * onetv_factory::DeviceGetListEx. Found device 7531:1 Jan 01, 2018 15:13:04.235 [0xf5347b90] INFO - * onetv_factory::DeviceGetListEx. Found device 7531:1 Jan 01, 2018 15:13:04.236 [0xf5347b90] INFO - * onetv_factory::DeviceGetListEx. Found device 7531:1 Jan 01, 2018 15:13:04.236 [0xf5347b90] INFO - * onetv_factory::DeviceGetListEx. Found device 7531:1 Jan 01, 2018 15:13:04.236 [0xf5347b90] INFO - * onetv_factory::DeviceGetListEx. Found device 7531:2 Jan 01, 2018 15:13:04.237 [0xf5347b90] INFO - * onetv_factory::DeviceGetListEx. Found device 4101:45397 Jan 01, 2018 15:13:04.237 [0xf5347b90] INFO - * onetv_factory::DeviceGetListEx. Found device 7531:2 Jan 01, 2018 15:13:04.271 [0xf5347b90] INFO - * device_manager_t::get_device_list. Device KATHREIN Sat>IP Server (192.168.178.24) - 0, id dvb#sat2ip#0#uuid:7f764937-d0d7-11e1-9b23-00d0551c4981, tuners 1, state 0, standards 4 Jan 01, 2018 15:13:04.272 [0xf5347b90] INFO - * device_manager_t::get_device_list. Device KATHREIN Sat>IP Server (192.168.178.24) - 1, id dvb#sat2ip#1#uuid:7f764937-d0d7-11e1-9b23-00d0551c4981, tuners 1, state 0, standards 4 Jan 01, 2018 15:13:04.272 [0xf5347b90] INFO - * device_manager_t::get_device_list. Device KATHREIN Sat>IP Server (192.168.178.24) - 2, id dvb#sat2ip#2#uuid:7f764937-d0d7-11e1-9b23-00d0551c4981, tuners 1, state 0, standards 4 Jan 01, 2018 15:13:04.272 [0xf5347b90] INFO - * device_manager_t::get_device_list. Device KATHREIN Sat>IP Server (192.168.178.24) - 3, id dvb#sat2ip#3#uuid:7f764937-d0d7-11e1-9b23-00d0551c4981, tuners 1, state 0, standards 4
This post forums.plex.tv/discussion/comment/1585675
is describing a similar symptom and mentions some Setting (“UnsupportedTuners”) that was activated to resolve the issue.
Unfortunately I’mm too blind to find such a Setting on Plex and neither did I see it mentioned anywhere else.
Did I really just miss a simple Setting somewhere?
Any other Suggestion as to why the Tuner is not properly discovered (showing in the web ui)?
Thanks in advance
