Server Version#: 1.29.2.6364
Player Version#:9.10.1.36024
So, Ive had an issue for quite some time and its bugging me out because I cant play my music library through my shield device. It works well from the webui but not through the android client on my shield. It also works fine using plexamp, however the client is not well suited for android-tv, it works but functionality is clunky at best.
Whenever I start playback of audio it tells me that an error occured while playback of the item.
I get a log entry with this message:
Nov 13, 2022 04:15:09.575 [0x7fcc3cc78b38] DEBUG - Failed to stream media, client probably disconnected after 2883584 bytes: 104 - Connection reset by peer
Complete logs attached in zip file
Plex Media Server Logs_2022-11-13_04-15-15.zip (4.1 MB)
Edit: I am placing this at plex players → mobile devices since this seems to be a client issue, the issue isnt there with apple-players nor the webui and plexamp works fine, android-mobile and android-tv clients however does not work.
