Connection to server is not fast enough
I have a movie 4K the keeps saying the connection to the server is not fast enough. I have the nvidia shield hard wired 1Gbps and my desktop Plex server 1Gbps hard wired. what else can I check? Just to add that all these video files worked 100% last week, I watched the movie straight through. Not sure if something changed on plex server software (i’m running Version 1.14.1.5488) I also have an AMD FX-6300 with 16GB ram that I formatted , installed plex server and have same issue so I know its not my server. Tried using my Nvidia shield and Xbox One both hard wired and server is hard wired same issues
below is one of the files
Media
  • Video Resolution 4K
  • Duration 2:31:25
  • Bitrate 41283 kbps
  • Width 3840
  • Height 2160
  • Aspect Ratio 1.78
  • Container MKV
  • Video Frame Rate 24p
  • Video Profile main 10
Part
  • Duration 2:31:25
  • File The.Martian.2015.Extended.Cut.UHD.BluRay.2160p.TrueHD.Atmos.7.1.HEVC.REMUX-FraMeSToR.mkv
  • Size 43.67 GB
  • Container MKV
  • Codec HEVC
  • Bitrate 40419 kbps
  • Bit Depth 10
  • Chroma Subsampling 4:2:0
  • Color Primaries bt2020
  • Color Range tv
  • Color Space bt2020nc
  • Color Trc smpte2084
  • Frame Rate 23.976 fps
  • Height 2160
  • Level 5.1
  • Profile main 10
  • Ref Frames 1
  • Width 3840
  • Display Title 4K (HEVC Main 10 HDR)
I figured it out, its some sort of issue with downloading the file from my google drive. I copied the same movies directly to my PC and they work fine
