Constant buffering with subtitles on
Help needed
Whenever I turn on subtitles (no matter which language) whatever I’m watching is buffering every couple of seconds, making it impossible to watch something… the buffering stops as soon as I remove subtitles. I prefer/need subtitles for some things so could really use some help.
Thanks in advance!
Plex Media Server version?
Plex Media Server platform? Windows, Linux, NAS, etc?
Plex client?
With subtitles disabled is the audio or video direct playing / direct streaming / transcoding?
With subtitles enabled, is the audio or video direct playing / direct streaming / transcoding?
You can check via Plex Dashboard → Now Playing + Expanded View.
Subtitle support varies across Plex clients. What direct plays on one client may cause transcoding on another. It may also cause “subtitle burning” where the subtitle is added to the video image, not sent as a separate track.
If your CPU is not powerful enough to handle the process, you will experience buffering during playback.
Here’s an example of subtitle burning: Playing a movie using Plex Web with VOBSUB subtitles enabled. The browser does not support such subtitles, so they must be burned into the video stream.
The entries are from the Plex Media Server.log file.
Aug 27, 2023 16:17:07.066 [0x7fd2bc7ecb38] DEBUG - [Req#5358d/Transcode] MDE: Dodgeball: A True Underdog Story (2004): selected subtitle cannot be converted to a compatible format, burning into video stream
Aug 27, 2023 16:17:07.068 [0x7fd2bc7ecb38] DEBUG - [Req#5358d/Transcode] Streaming Resource: Reached Decision id=33722 codes=(General=1001,Direct play not available; Conversion OK. Direct Play=3000,App cannot direct play this item. Direct play is disabled. Transcode=1001,Direct play not available; Conversion OK.) media=(id=99778 part=(id=101839 decision=transcode container=mp4 protocol=dash streams=(Video=(id=223124 decision=transcode bitrate=2147483647 encoder=h264_vaapi width=850 height=368) Audio=(id=223125 decision=transcode bitrate=256 encoder=aac channels=2 rate=48000) Subtitle=(id=223129 decision=burn languageCode=eng location=embedded))))
