Continue watching contains shows from other users
Hi there,
Since server version 1.41.8.9834 (Ubuntu server x64) i’m experience TV Shows watched by others (where I shared my library with) popup on my start screen as ‘continue watching’.
Someone else experiencing this?
With kind regards,
Buck
No, no one has my account. I also see it in Tautulli, when user x watching tv show x, it popups in my start screen. I remove it from my start screen out of the continue watching list and the next time user x streams it, it comes back.
This happens with al user that have access to my library.
Is the user located in the same local network as your server?
Or if they’re not, do they use a VPN to make them appear to be in this local network?
No, they are external users, I shared my librarys (Manage Library Access) to there own Plex accounts.
They are not on the same network, and does not have a VPN.
They live in different locations and al have an own Plex account
Switch off your trakt.tv synchronisation for a while.
See if the issue persists during that time.
Gonna try that, don’t use it anymore anyway haha.
How dit you know I use trakt sync?
It’s in your account, which I can see.
It was indeed the plextraktsync (GitHub - linuxserver-labs/docker-plextraktsync) wich wasn’t compatible/broken sync Plex Media Server version 1.41.8.9834
Because I didn’t use it anymore I just deleted it. So I have no solution if someone else encounters this issue.
Thanks OttoKerner!
