Continue Watching keeps disappearing (all clients)
Server Version#: 1.40.1.8120 (64-bit)
Every time I go into Plex lately, whether it’s on my Roku, Shield, or Web clients, the Continue Watching section is gone about 80% of the time. I can usually get it back by going down to the TV section, letting it load shows, then going back up. Sometimes I have to do this 2 or 3 times before it shows back up. After playing something, it’s often gone again and I have to repeat that to get it back. What is happening, and how can I get it to stop doing this?
When I first go into my client (this is a Shield Pro)
When I go down to the TV section, let it load, then back up (in this instance, it took 2 tries to make it happen)
This is still happening to me, through multiple updates. It’s very frustrating. I don’t know why it appears to be just me, though.
its not just you.
it is likely excessive ‘slow queries’ or possibly other related database issues.
if you have very large libraries, and/or older/slower server hardware, then there are some queries that pms is using that can take a long time to process and return results.
hopefully this will be resolved or improved in upcoming 1.40.2+ versions.
but in the future, exact hardware specifics (cpu/ram/etc), if plex database is on ssd or hdd, if running virtualized in some manner, and server logs that capture during a time where the problem recently occured (and about what time you experienced the problem).
so far working better for me
do note, database changes with this release, can take much longer to start depending on database size and cpu/disk speeds.
be patient.
This is still happening multiple times per day. Almost every time I finish watching something and it goes back to the main “Home” screen, the Continue Watching is missing.
Yeah, on shield disappears everytime the app launches a new session.
